  #1
Old June 24th, 2005, 03:19 PM
AlaskaMilt AlaskaMilt is offline
Default Mercury Jet slips into reverse
I have a 1995 Merc 35 hp with a jet unit. It is a tiller handle motor with the small separate jet shifter. When up on plane the jet unit will pop into reverse, lots of noise and spray and a little scary. What can I do to keep the jet in the forward setting.ThanxMilt
  #2
Old June 24th, 2005, 04:14 PM
dajohnson53 dajohnson53 is offline
Default Re: Mercury Jet slips into reverse
This is the fabled and dreaded mis-adjustment of the reverse gate (AKA reverse cup and reverse boot). As you know, there are no gears involved in the outboard jet - reverse is achieved by a gate or cup going over the jet outlet redirecting the jet output backwards. The default position of the cup is hanging down below the jet outlet. Reverse requires that the cup be pulled up and over the jet outlet. What is happening is that your's is mis-adjusted so that when you're going forward, the cup is not haning clear out of the way, but is slightly raised so that the jet stream hits it. If it hits at just the right (wrong?) way, the force of the jet output will actually pull/push the cup up over the outlet and thus causing reverse.Although all outboard jet lower units are very similar, there are differences in the brackets that are involved in attaching the forward/reverse cable to the unit. I have no experience with the units that use a shift rod instead of a cable. I can't give you specific instruction on how to adjust yours - but I found mine to be pretty self explanatory. As a start, watch it closely as someone (or yourself if you can reach) shifts between forward, reverse and neutral. The bracket that attaches to the cable should show you the spot that will "lock" (a soft lock) itself into position at full down (forward) position. This is the first and most important adjustment. From there, you adjust neutral. Neutral is just a medium position of the cup which diverts some of the jet flow forward, some backward to be approximately neutral. In my experience it's hard to get a very solid neutral and I usually have a little forward push in neutral. But again, as you've discovered, the most important adjustment is to make sure forward is good and solid.I would guess that if you look at it, you can figure out how to adjust it.To get a user's guide, you need to go to a local dealer of the product, or contact Outboard Jet company directly. I contacted them by phone through their website http://www.outboardjets.com and found them very helpful. Their website has some printed material, TA and FAQs, but I don't recall a full user's guide - you'll probably have to call them.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motor slips out of reverse 1985 90 HP in-line Merc. 111torrance111 Mercury & Mariner Outboards 3 July 7th, 2006 09:11 AM
25hp johnson slips into reverse quietstorm Johnson & Evinrude Outboards 4 December 7th, 2004 11:53 AM
Mercury 135 slips out of gear JonathanMoore Mercury & Mariner Outboards 1 August 25th, 2004 05:18 AM
9.9 two stroke slips out of reverse DuPont Spinner Yamaha & Suzuki Outboards 0 July 19th, 2003 08:24 PM
'75 Mercury 850 slips at higher RPM cpad33 Mercury & Mariner Outboards 2 April 24th, 2002 08:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
