  #1
Old June 23rd, 2005, 02:49 PM
flstanleyii flstanleyii is offline
Default Trigger test for '72 80hp Mercury
I have a '72 80hp, 4 cylinder Merc (serial # 3312746) that has no spark to any of the plugs. With the help of this forum, I believe I've isolated the problem to a bad trigger. At Laddies suggestion, in his post to Bryan22 on June 16, 2005, I disconnected the mercury switch, placed the engine at TDC, disconnected the distributor side terminals, jumped the brown and white posts on the 3 terminal side of the switch box and arced the black post to ground. With the switch turned on, I do have fire, which indicates a bad trigger. As parts are hard to find for this year of engine, I'd like to replace the entire distributor, if I can, but of course that means going to used parts. Prior to spending a lot of time and money on a "pig-in-a-poke", is there anyway to test a trigger with the distributor out of the engine? I have a couple of leads on used distributors but they've already been removed. I've checked the forum archives for some kind of a test, but have had no luck. As this is my first posting to this group, perhaps someone could point me in the right direction within the forum or perhaps knows of a way to test a used trigger if the topic hasn't been covered before?? As always, any and all comments would be greatly appreciated!!Thanks in advance!!Frank
  #2
Old June 23rd, 2005, 04:37 PM
Laddies Laddies is offline
Default Re: Trigger test for '72 80hp Mercury
With the trigger wires hooked up crank the engine with the starter, you must have 9 1/2 volts on the white post with the starter turning the engine, ck the brown trigger wire 9 volts min., ck between the blk and the white wires with a DVA you should have 3 volts, low voltage between them means a bad trigger--Bob
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old June 23rd, 2005, 04:53 PM
Thanks, Bob!!I have an extra pair of hands coming by and when they get here, I'll give that a try. However, if worse comes to worse and it is the trigger, any way to test one that's been removed from the engine??Thanks again!!Frank
  #4
Old June 23rd, 2005, 05:06 PM
Sure just hook up the wires and turn the dist. by hand, you can't ck for starter load however and remember to stay away from the high tension lead
__________________
  #5
Old July 3rd, 2005, 07:12 AM
timmathis's Avatar
timmathis timmathis is offline
Yas that is right if your trigger has A roter on it. If not you can test it with A feeler guage.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
does the fly wheel have to come off? to test can a stator and trigger be test jtp7571 Force & Chrysler Outboards 3 August 8th, 2005 09:55 PM
TRIGGER WIRING 1978 80HP MARINER DWF Mercury & Mariner Outboards 3 March 26th, 2005 05:53 PM
trigger test mwbaughan Mercury & Mariner Outboards 5 September 11th, 2004 06:56 AM
'71 80hp trigger wires chuckster819 Mercury & Mariner Outboards 2 August 3rd, 2004 06:39 AM
trigger test katbird Mercury & Mariner Outboards 1 March 30th, 2004 01:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
