Re: engine size
I'll put it to you this way. My tri-hull center console is 16.5 feet, rated for 145 hp, and has 125 hp. It certainly gets it done, but I am on a passive hopeful search to come across a 150 horse. If you pack several people on, you'll really wish you had the 115. <br /><br />Tri-hulls need more power than a v hull of the same size, there is more wetted surface, which robs power. My rig isn't quite as happy if I stack four carcasses in it, but it does come on plane and cruise decently. It just takes a bit longer to get up on plane. <br /><br />A 70 horse may not get you on plane when fully loaded with several people, then you'll be cruising around with the bow in the sky or at displacement speeds. Trim tabs can help, but if you are going to spend the loot, apply the loot towards a larger engine. It won't work as hard, and you don't have to run it at full throttle all the time. A larger engine running at part throttle will get better economy and last longer than a smaller engine running wide open. Either way you go, good luck...
