  #1
Old June 12th, 2005, 04:06 PM
jaguar1 jaguar1 is offline
Default 25 HP mercury marine-lost reverse
I have lost reverse. The boat is new to me and I recently changed the impeller but that was done 5 trips back and couple tankfuls of gas. The cables do move freely but it will not shift into reverse.Oh and there is no grinding it just appears to have locked itself out of reverseIt does appear to be internal. Serial # 0T057452 2000 25EL. 25 HP 2000 model Many thanks
  #2
Old June 11th, 2007, 09:04 PM
cabbage cabbage is offline
Default Re: 25 HP mercury marine-lost reverse
Join the club, my motor is the same year and hp. The gear shift is in the handle. A goofy setup. I have lost reverse twice. It is in this condition currently . The first time I took the lower unit down and push the gear rod down to reverse. It appeared to be firmly in gear. I put the foot back together and had a heck of a time getting the top pin in the rod hole. It worked great until the last fishin' trip. Now, its not working again. I think its a model defect. Hopefully, we both can get an answer.
  #3
Old June 16th, 2008, 09:41 AM
Boiler_Pappy Boiler_Pappy is offline
I have also lost reverse. It worked as I backed off of the trailer, but then after running in forward full throttle, it locked. I tried to engage manually by removing the linkage and using a 1/2 wrench on the linkage to the lever. I was unable to shift it into gear. I noticed that if the full foward goes beyond a certain point, the linkage gears roll out of position. Has anyone discovered cause of problem?
  #4
Old June 15th, 2009, 05:07 PM
aj584211 aj584211 is offline
I realize this is a late response but just saw the thread and wanted to add my experience with my 25 hp Mercury.
There is a "washer" that rides on the shift rod. The washer is intended to lift the bent heavy wire rod that lifts the tilt release lever when shifted into gear.
That washer got jammed on my lifting rod and would not let the shift rod move to the reverse position even though the shift rod could be moved with a open end wrench.
The solution was to remove the lower end to drop and access the washer replacement site on the shift rod and then reassemble with new washer in place.
The caution note from my tech is that we are never to move the shift lever to reverse without the engine running or at least manually turning the prop to allow those gears to engage.
My kids and I have now learned our lesson...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OMC Lost Reverse RC Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 14 June 29th, 2006 11:08 PM
Lost my forward and reverse, HELP!!!!! longisldr Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 29th, 2005 07:06 PM
470 Merc lost reverse jfc092 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 April 25th, 2005 10:35 AM
Lost forward / reverse simultaneously jsouthco Johnson & Evinrude Outboards 3 August 10th, 2003 02:26 PM
Mercury 25hp lost forward and reverse dleve Mercury & Mariner Outboards 3 July 21st, 2003 06:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
