  #1
Old June 9th, 2005, 10:22 PM
beaverhound beaverhound is offline
Default Mercury 25hp fuel pump problem
I have a 1997 25hp merc tiller. It sat for 3 yrs. i replaced plugs, waterpump, fuel pump diaphram, and completely disasembled the carb and cleaned. i put it all back together and tried to start. i primed the fuel filter and pulled til i was blue. the prime on the carb wont even squirt any fuel. so then i shot a squirt of ether in the carb and opened the throttle manually and gave a pull. fired right up but the minute you let it below say 2000 rpms it stalls. the pump isnt pumping so i even checked the vaccum lines and the plate the carb mounts to for restriction but theyre all clear. i wish i could bypass the pump but on this model the pump is cast to the side of the carb. any suggestions?
  #2
Old June 10th, 2005, 11:46 AM
groovy.dude groovy.dude is offline
Default Re: Mercury 25hp fuel pump problem
Your post is a bit confusing. How are you sure that it is not pumping fuel? I am not familiar with your particular model, but on my smaller engine the first things do it re-check all the gas lines for cracks or leaks. And also I would look at the linkage in the float boawl to make sure that all the measurements are correct. One time while puttting my carb back together I bend the linkage on the float and it cause me some grief. I am no expert by any means!
  #3
Old October 31st, 2008, 11:03 PM
Starcraftguy1's Avatar
Starcraftguy1 Starcraftguy1 is offline
if you are idling at 2000 rpm the pump is pumping.Seems like a carb problem to me.Did you set the floats according to specs?
  #4
Old November 3rd, 2008, 04:47 PM
hamit59 hamit59 is offline
Send a message via MSN to hamit59
Question Re: Mercury 25hp fuel pump problem
I would never spray either into a 2 stroke there is no lube in it. In stead spray premix in it to test.
Will this motor run with out spraying the carbs down?
My first thought was you have a needle valve stuck, or your float level is set wrong.
If your fuel pump is in question tee in a vac gauge. The reading should be 2.5-3 hg
When you cleaned the carb did you soak it? It could be a clogged low speed jet.Not knowing the serial number of your motor. I can't look up the carb they used on it. Try turning out the mix screw to 2 turns to see if will idle.
post back your findings.
__________________
Hamit
BT1 USN ret
  #5
Old November 21st, 2008, 11:43 PM
robster1213 robster1213 is offline
when you say to T into the line. Which line are you T-ing in to? The fuel line? And just check it for vacuum? And that is what the pump is pulling in? I can't think of another one besides the little ones that tap into the transfer ports? But I would think they would read + and - depending on the stroke as they accuate that diaphram..... right?
I am having a similar problem. Mine will start with a prime, but then acts like it's not getting enough fuel. The primer bulb seems to feel ok, and if I squeeze it, it makes no difference. maybe float level or a sticky needle and seat??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
97 Mariner 25hp..fuel pump?? Harker Mercury & Mariner Outboards 5 July 29th, 2009 10:36 PM
Mercury 200HP EFI Fuel Pump Problem daguvna Mercury & Mariner Outboards 4 March 28th, 2007 12:02 PM
94 johnson 25hp fuel pump cooperjd Johnson & Evinrude Outboards 3 May 2nd, 2006 10:15 AM
merc 25hp water pump problem H2Odog Mercury & Mariner Outboards 4 January 7th, 2006 06:07 AM
*** 1976 Mercury 1150 115hp - ENGINE DIES AFTER STARTING. FUEL PUMP PROBLEM? HEL brianmerc Mercury & Mariner Outboards 15 November 11th, 2002 09:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
