I have a 1986 90HP Merc that is doing something that I can't seem to figure out. The hooks that grab onto the trim adjustment pin (no power trim) will not release when the motor is in gear. I pulled the lower end off and the cam looks fine. I put it all back together and found that if I tilt the motor by pulling the pin, the hooks move freely. Not so when when the weight of the engine is bearing against the pin. The spring looks good and seems to work properly. I found out about this problem when I hit a rock (going very slow since I knew I shouldn't be in that part of the river) and noticed that the motor didn't slip over - the whole boat shuddered a bit. When I took it out of the water to trailer it, I found that it wouldn't release. Anybody have any ideas? Thanks for any thoughts. I hope I can get this fixed before summer ends!
