  #1
Old May 30th, 2005, 07:24 AM
fisherman_freddy fisherman_freddy is offline
Default Loosing power 3 cylinder Mariner 60 1987
HiI have a 1987 3 cylinder Merury Mariner which looses power after 3 miles at 4k revs. If I let her cool down she runs again at power but then drops again. Other symptoms are blipping at speed having lost power. Have check compression, plugs, water comes out of tell tale pipe, timing ok, renewed carb float valves but no improvement.I suspect overheating but engine feels ok - hot to touch but not too hot. I have also checked the warning horm - ok. Does anyone know how to check the temp sensor just to double check ?.Any clues to what the problem is would be gratefully received.
  #2
Old May 30th, 2005, 07:48 AM
Moody Blue Moody Blue is offline
Default Re: Loosing power 3 cylinder Mariner 60 1987
Is this a new problem ? Are you using the oil injection system or pre-mixing ? When was the last time the water pump impeller was changed ? Is the vent on the gas tank open ?To check the horn operation, turn the key to RUN and remove the sending wire from the sensor and touch it to ground. The horn should sound.To check the sensor remove it from the engine. Using an OHMMETER check for continuity between the wire terminal and the body of the sensor. It should be open circuit or no connection. Drop the sensor into boiling water for a minute then remove it and quickly do the same test. It should now be a closed circuit or a short.
  #3
Old May 30th, 2005, 07:51 AM
Laddies Laddies is offline
Test the sensor with a ohm meter in hot water on a stove, the popit valve could be stuck not letting the motor to dump water at high speed
__________________
PLEASE, no service questions in PMs thats what the forums are for.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'95 Mariner 125 loosing power craig7241 Mercury & Mariner Outboards 0 July 9th, 2006 06:14 PM
yamaha 95 250 loosing power k9nicko Yamaha & Suzuki Outboards 3 June 25th, 2005 05:11 PM
1987 Mercury 60 hp long shaft, 3 cylinder, power T&T dynapac Mercury & Mariner Outboards 2 April 17th, 2005 11:55 AM
Loosing Power LeeinFL Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 February 2nd, 2004 03:01 AM
enigine loosing power kelstar777 Johnson & Evinrude Outboards 2 January 3rd, 2004 02:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
