  #1
Old May 18th, 2005, 09:20 AM
Rboetsma Rboetsma is offline
Default 1980 Mercury 40 4hp 2stroke exhaust holes & water pump
I have a 1980 Mercury 40 4hp 2stroke outboard motor. It runs fine but I am wondering if water from the pump in the lower unit should be coming out of the 8 small holes that are up higher on either side of the lower unit where the exhaust comes out of? I'm trying to find out if there's suppose to be a "pee hole" or if the water is just expelled from the center of the prop or if these 8 holes are the "pee hole"/exhuast outlet. When I run it at a low speed no water comes out to the 8 holes but when I run it wide open throttle some water lightly sprays out of the holes along with exhaust. Is this all right or should a steady stream be coming out of these 8 holes? I have taken the lower unit apart and the impeller seems fine, the tube is clean and isn't clogged and the motor doesn't seem to overheat at all. I am just more worried that it might over heat if the water pump isnt working correctly. Also, there is no obvious "pee hole" anywhere else on the motor. Any knowledge on this matter is much appreciated.
  #2
Old May 18th, 2005, 01:22 PM
phatmanmike phatmanmike is offline
Default Re: 1980 Mercury 40 4hp 2stroke exhaust holes & water pump
pee hole: when looking at back of motor( spark plug side) its on the bottom of the lower cowl pan, just around the corner from the back on the rightand yes, you SHOULD have water peing outa there! if not, get a manual and a waterpump kit!
  #3
Old May 19th, 2005, 07:17 AM
Thanks, Looks like I have some work to do...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
water pump 150 crossflow 1980 Benny1963 Johnson & Evinrude Outboards 3 March 20th, 2007 06:47 AM
No water coming out exhaust holes in mid section ba_50 Johnson & Evinrude Outboards 3 November 29th, 2006 07:27 AM
Testing water pump on '73 Johnson w/o pee holes green heron Johnson & Evinrude Outboards 2 June 9th, 2006 06:37 PM
omc lower foot water pump holes SILTHUNDER77 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 5th, 2005 08:11 PM
checking water spray from exhaust holes Dan Beisel Johnson & Evinrude Outboards 4 July 22nd, 2004 11:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
