  #1
Old May 18th, 2005, 06:39 AM
hooksetter62 hooksetter62 is offline
Default 40 hp mariner mag 4 cyl--oil&cold start
i have a 1989 mariner mag 40 4 cyl,it seems that the oil injection is smoking much more than normal,smokes very bad and seems to be running rich. is it possibe for me to disconnect the oil tank and just add oil to my fuel tank? as i dont trust the pump system anyway. also what would be the proper ratio of oil to gas? 50-1? i use a 12 gal tank. cold start problem is how can i check the choke solenoid to see if it is priming the carb? i have to crank and crank before it will start, some times it may take 5-10 minutes. dont want to take my starter out. how does the choke solenoid deliver the fuel for cold start? i only have about2-3 hundred hours on this motor and it has always run smooth, like a car. i have had new plugs installed and the lower carb overhauled as it was leaking fuel. all and any help would be appreciated, as the marinas are very very busy and VERY EXPENSIVE. many thanks- ed eckert gladwin michigan
  #2
Old May 18th, 2005, 08:49 AM
minstral minstral is offline
Default Re: 40 hp mariner mag 4 cyl--oil&cold start
You can disconnect the oil tank and run a 50:1 mix in the fuel, but most likely the oil control arm is misadjusted. As for the choke if you disconnect the small hose from the choke solenoid at the carb/carbs and place a small container under them when you depress the choke there should be a small amount of fuel come out. Also there should be a red lever on the side of the choke solenoid. That is the manual choke rotate it to the up position and see if motor starts better, be sure to move it back to down position
  #3
Old May 18th, 2005, 01:35 PM
Scali Scali is offline
did you change oil brands ?
  #4
Old May 19th, 2005, 09:07 AM
well im going back to quick silver,other brands just dont work as well, but i did disconnect the oil tank and im going to just add oil to the gas. i have more control over the mixture. i did check out the choke operation but the line from the choke solenoid goes behind the electronic control module(had to remove) then goes into a three way valve that feeds directly into the cyls,and yes there was fuel there when i used the key switch. thanks to everyone for there help and suggestions,i guess i owe you a cold one. Ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
how cold for the cold start button? TenE307 Mercury & Mariner Outboards 12 September 1st, 2005 12:43 PM
mid-1990's mariner 3 cylinder 60 hp hard cold start kentrx1 Mercury & Mariner Outboards 4 July 17th, 2005 05:58 PM
Mariner 150 - hard to cold start and stalls on low revs Gnirts Mercury & Mariner Outboards 9 August 13th, 2004 05:23 PM
Mariner 1995 75hp Won't Cold Start spaniardking Mercury & Mariner Outboards 5 May 20th, 2002 05:23 AM
mariner cold start flatsman Sailing 1 August 21st, 2001 11:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
