  #1
Old May 17th, 2005, 03:30 PM
kelman kelman is offline
Default 75 MERCURY FLYWHEEL LOCKED
This is a 75hp mercury 1996 model. THe boat ran great on the muffs before taking to river. I had the water pump replaced a couple of days ago. When the boat was put into water i cranked it and it ran fine. Water pressure seemed okay. After running at full throtle about 5200 rpms the moter suddenly died and would not crank the starter will engage but flywheel is locked. THe forward and reverse gears are there but in forward the prop will spin and make a clicking sound in reverse no movement is allowed. Any help would be great just wondering if this motor sounds salvageable.
  #2
Old May 17th, 2005, 04:10 PM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: 75 MERCURY FLYWHEEL LOCKED
It could be the motor or gearcase. You won't be able to tell by spinning the prop. Remove the gearcase and see if the flywheel turns then. You might also check your gearlube. Chunks of metal in the lube wouldn't be a good sign. A bit of metallic isn't unusual.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old May 17th, 2005, 04:18 PM
Ben Konopacky Ben Konopacky is offline
K ;can the eng.be turned over with a pull cord ?if it could be turned over then you might have a low voltage prob. or loose batt. connection .
  #4
Old May 17th, 2005, 06:04 PM
no the pull cord cannot turn the flywheel nor can my arm. Tryed that but no luck. If i take the lower unit off and the flywheel turns that will definately tell me if it is in the motor or gears correct?
  #5
Old May 18th, 2005, 04:45 AM
Pretty much. Could be both, but nobody's that unlucky.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 150hp XR6 locked up dbs522 Mercury & Mariner Outboards 4 October 27th, 2003 11:09 AM
1980 Mercury 7.5 motor locked wildeman Mercury & Mariner Outboards 4 January 12th, 2003 01:47 AM
tilt trim locked in up position (mercury 85 hp) barrycyphers Mercury & Mariner Outboards 0 September 14th, 2002 12:51 PM
1992 Mercury 150 HP Motor Locked Down 714R Mercury & Mariner Outboards 6 March 24th, 2002 05:44 PM
Mercury 350 35hp, locked up? or Not !! lynnyrd Mercury & Mariner Outboards 12 May 22nd, 2001 08:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
