Have a 90's model, oil-injected, 60hp Mariner(0B538238), been sitting in dads garage for 2yrs, worked when parked. Aquired it 3wks ago as a graduation gift.
It has, since I got it a problem where it starves for fuel to the point that it will die. If you catch it before it dies and squeeze the bulb you can save it. The bulb is soft and will harden as you pump it.
Initially suspected a leak in the lines. Replaced hoses from tank to oil injection pump, oil injection pump to motor. New bulb, some suspect zip ties replaced also. Dumped and refilled oil tank. Believe fuel tank is o.k.? Have a new one that I am going to hook up once I obtain fittings.
Noticed yesterday while running it in yard that the filter between the fuel pump and the carbs would fill when the bulb was manually squeezed, but then as the motor runs, the fuel is then drained(or sucked) from the filter to the point where either the motor dies or it refills to about a third of the filters volume when full. When this happens, the filter is visually empty and the motor is starting to run poorly, the filter suddenly fills to about a third of its capacity. It has the same effect as if I manually squeezed the bulb. The motor picks up if it refills in times, otherwise it dies. I did see sediment in the filter, replaced filter.
No change noticed in anything attempted so far. Beginning to wonder about the fuel pump? Shouldn't that particular filter stay full once the line is primed and the engine is running? Is there a pressure I should expect to see out of the pump? Is their a way to test it?
Any help and insight would be greatly appreciated....
