Still no spark on 72' 115 Mercury straight 6??
Chris1956
Re: Still no spark on 72' 115 Mercury straight 6??
Stant1man, Achris gave you a pretty good troubleshooting procedure. Here is one courtesy of Clams Canino. Why not try it and post results?<br /><br /><br />MERCURY BATTERY-POWERED CDI TEST <br />FOR DISTRIBUTOR MODELS<br /><br />This test is for the 332-2986 switchbox used from 1967-1978 on all the inlines.<br /><br />This test assumes your coil is good (most all are).<br /><br />DISCONNCT BATTERY <br /><br />1. Turn off ignion<br />2. Disconnect all 3 wires on the distributor side of the switchbox.<br />3. Remove the HV lead from the coil to the center cap (remember it unscrews<br />from cap)<br />4. Reconnect that HV center lead to the COIL side only.<br />5. Position that HV lead about about 3/8" from ground (block, shrouds etc)<br />and find a way to hold it there.<br />6. Jumber the brown and white terminals on the dist. side of the switchbox<br />together.<br /><br />RECONNECT BATTERRY<br /><br />7. Check that you have +12 V at red terminal.<br />8. Turn on ignition and verify +12V at white terminal (on red terminal side)<br />9. Touch the black terminal to ground - unit should cause spark each time<br />you touch ground.<br /><br />If that passes and it won't fire at all, suspect the trigger
achris
More fish than mountain goat
Stan,<br /><br />If you wish to get your post back to the top of the page, just 'bump' it. Starting a new thread confuses everyone. (I'm really easy to confuse). Also you may have to leave it a bit longer for people to get back to you. I for one have a day job and some sleep to get (sometime!).<br /><br />Chris.......... aka Achris.........
PierBridge
Originally posted by Chris1956:<br />[QB]MERCURY BATTERY-POWERED CDI TEST <br />FOR DISTRIBUTOR MODELS<br />This test is for the 332-2986 switchbox used from 1967-1978 on all the inlines.<br />
How about a 1966 950ss with thunderbolt ignition.<br /><br />The 1967 9500ss has the same specs as the 1966.
Clams Canino
Same specs - different box.<br /><br />On the 66 there is just ONE post on the distributor side. That switchbox is unique to 1966. Bump that post to ground to check spark.<br /><br />-W
