  #1
Old May 1st, 2005, 08:44 AM
shamone79 shamone79 is offline
Default Mercury 115 hp efi with Quicksilver controls- Throttle problems
Hi. From UK and new to forum so please bear with me!My father-in-law and I are in the middle of re-commisioning his 96 Bayliner Capri for summer use. The engine and gearbox are all ready but we are having major troubles with the controls.The boat has Quicksilver 3000 classic controls fitted which have got extremely stiff in operation. We have checked that the cables are free and are positive that the fault lies in the control box.Can anyone give us a contact with regards to obtaining a service manual for these controls? Before we get to the point of buying a new control box we would like to have a go at sorting out these if we can. We are having trouble just getting the control lever off!! There is a grub screw which we have removed but it seems to be stuck solid.Any help/comments received will be very gratefully received. Many thanks.
  #2
Old May 1st, 2005, 07:10 PM
fierro fierro is offline
Default Re: Mercury 115 hp efi with Quicksilver controls- Throttle problems
try some graphite if you can get it into the controls and try working them. a little bit of graphite goes a long ways.
  #3
Old May 2nd, 2005, 02:24 AM
Thanks for that. As soon as I can get the controls apart I will graphite grease everything up. The problem is at the moment I can't even get the lever off! Either it's seized or I'm doing something wrong! By the looks of things the handle has to come off before you can take the control box out. I'm a professional car mechanic so am pretty competent when it comes to cars but things are generally a lot cheaper if you break something on a car than a boat!
  #4
Old May 2nd, 2005, 05:36 PM
Laotzu Laotzu is offline
You can buy a book from this forum but the shipping cost might be prohibitive. Must be somewhere there where you could get one. Clymer has a good Merc Manual. Go on Google and ask for Clymer. They may have a European site. The book won't necessarily help you with your problem. Covers the wiring, switches, etc. However the control itself is quite simple. Just cables going around cams and out to the motor.Is there a tension knob on the front end of the unit? try turning that to free up. How about the carb linkage? Any binding evident?By the way, my son is married to a girl from Swindon. He met her there when he was in the USAF Strategic Air Command and spent some time at the RAF base in Swindon.
  #5
Old May 3rd, 2005, 02:21 PM
Thanks for the suggestion Laotzu. Like you say, we have an excellent factory Mercury manual for the outboard but nothing for the controls. Can't find anything on the web either.Anyway I took the complete side panel off the boat to access the rear of the controls and all is fine inside. I disconnected the cables from the outboard and everything is as free as a bird so looks as though the stiffness is in the gearbox itself. We have adjusted the cables and greased everything up and it feels a little better. It probably needs a little use as it has been stood doing nothing all winter.It would be very interesting though to find out how you get the damn lever off. It looks as though you have to prise off the 'Throttle only' button but I can't get it to budge. Also there is a little grub screw that even when released does nothing to let you remove the lever. Hey-ho and see how we go!Laotzu- I am located in the South-West of England (Cornwall) but Swindon about 2.5 hrs drive. Can't say I have been there directly but pass it often on my way to London. Swindon is the home of Honda UK if you didn't already know. That's all I know about the place!! Thanks again
  #6
Old May 3rd, 2005, 04:08 PM
I took mine apart, but it has been several years and I didn't have any trouble so I can't make any suggestions.Jerry
  #7
Old May 3rd, 2005, 07:25 PM
Moody Blue Moody Blue is offline
This site has lots of parts dwgs for controls. SCroll to the bottom of the page and start looking under -controls-. Many different models to choose from. Sure yours is there somewhere. http://www.mercruiserparts.com/selec...sp?type_id=*** in the address above, replace the *** with A S S (no spaces) for assembly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Quicksilver throttle/Mercury EFI 225 issue jsutich Mercury & Mariner Outboards 0 May 30th, 2006 02:40 PM
Mercury Quicksilver Controls jefferry28 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 24th, 2005 07:25 AM
quicksilver controls bonitoman Yamaha & Suzuki Outboards 0 May 9th, 2004 05:01 PM
Problems with Quicksilver controls/gauges for 200hp merc blackmax JerseyJim Mercury & Mariner Outboards 17 June 2nd, 2003 07:08 AM
Mercury Quicksilver Shifter Problems Bryan Mercury & Mariner Outboards 5 July 10th, 2001 11:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
