  #1
Old April 29th, 2005, 05:44 PM
Speed Freak Speed Freak is offline
Default Tilt/Trim leak on Mercury 60
Just bought a boat that has been sitting for 3 years. The trim goes up and down fine out of the water but if you trim up while driving the motor goes right back down. It does not go all the way down but almost all the way. If you are at any speed it will not go up at all. The motor is a 1997 60 HP Mercury OB. What do you guys think it is?Is there a rebuilt kit I can buy for the pump?Where can I buy parts? Thanks! Guy
  #2
Old April 29th, 2005, 07:29 PM
Laddies Laddies is offline
Default Re: Tilt/Trim leak on Mercury 60
Ck the o rings on the manual release valve, you will have to remove the E/ring to remove the valve from the pump
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old April 30th, 2005, 12:41 PM
Ok I see the e-clip and I am going to pull it out to check to O-rings. What kind of fluid do I use to refill the unit? The old fluid is red looks like transmission fluid. Thanks Guy
  #4
Old April 30th, 2005, 01:20 PM
OK I put new O-rings in, the old ones were hard. I think it did help but it still falls when I put my weight on it.What next? Thanks Guy
  #5
Old April 30th, 2005, 04:57 PM
Sorry I didn't get back sooner, there are a few things that could be still causeing the problem, a bad o-ring on any one of the 3 cyl. there is a ck inside the starboard trim cyl. that could be bad, but If I had to shoot a guess I would say there is dirt in the release valves on the tilt cyl. any of these repaire you are going to need a manual. If you can't come by a mercury I think SELOC has a good tilt/trim section in there manual---Bob
__________________
  #6
Old April 30th, 2005, 06:17 PM
BobThanks for the help. I will get a manuel this week and pull it apart next weekend. Guy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tilt/Trim Cylinder leak streetdoc Johnson & Evinrude Outboards 0 April 20th, 2006 07:29 AM
Tilt/Trim Pump Leak dorchard Mercury & Mariner Outboards 3 September 12th, 2005 07:31 PM
trim tilt leak JOHNSON110 Johnson & Evinrude Outboards 3 July 31st, 2005 05:22 AM
150 V6 Tilt-Trim Leak Down ?? garyj Mercury & Mariner Outboards 6 July 2nd, 2004 09:16 AM
tilt/trim leak sterling Mercury & Mariner Outboards 1 June 21st, 2002 09:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
