1st check the pee hole for obstructions.
Then drop the lower unit again and jam the end of a garden hose up against the water-pipe and see if it flows OK with you force feeding it water.
Sometimes there's more than the impeller at issue, the rest of the pump has to be in good shape too.
-W
