Re: water in gear oil
obster, I have found that the waterpump base seals seem to fail most often. The good news is that these are the easiest to replace. These seals consist of two seals between the water pump base and the drive shaft and a gasket and o-ring between the waterpump base and the gearcase. I recommend you purchase a waterpump base, and an impeller kit. Also get some instructions or a manual to assist your work. Install the waterpump base, impeller and the necessary gaskets and oring. If this fails to solve the problem, you may want a professional to replace the propshaft and shiftshaft seals
