My 94 225 was running really well up until three days ago. It feels like it is not hitting on all cylinders. I have comp tested it, changed plugs, drained the carbs..still runs the same. I checked for spark on all plug wires and they seem ok. Once in a while when driving the boat it will start hitting on all 6 and take off...but other than that it runs like crap. The foam insulation in the motor cover started falling off and it looks like the alternator/flywheel made a real fine foam mist out of it...wonder if the carbs sucked any of this in? Or maybe a reed problem? Thanx...
