Re: Steam From Exhaust Ports
thanks, John, will check for piston crown steam cleaning, though the plugs are new.-also, is there any easy way or place to install a temp gauge without engine mods? I'd like to keep it all original if possible. From what I can tell, the only places water can enter the exhaust short of a crack somewhere is the exhaust jacket gasket or plate, or the factory hole at the base of the powerhead, which obviously is designed to let water into the exhaust port! Maybe cleaning out the corrosion there is now creating a healthy dose of steam?? if not, if the exhaust water jacket leaks a little into the exhaust will it hurt anything?
cheers, nathan on reviving your '61. I have learned volumes in the last few months about this motor. the pee-hole on mine is, as you face the spark plugs or exhaust port, just under the cowling beneath the powerhead--not on the center section where the exhaust port is. It is on the left side and pees more or less straight down. If you look down at the base of the powerhead, the hole is just inside of where the gasket is. So turn your head upside down and look straight up (skyward) about midway between the cable attachments and the exhaust port.--It's about 3/16ths or so in diameter. Also, try poking a wire up it to get water... Or, does it pee when you flush the motor with the hose? If so, probably replace the impeller pronto. And I wouldn't run it too much until it pees.
cheers, Paul
