most merc,s are set to 550-650 in gear ..
usually results to about 750-900 in neutral..thats IN the water..
check your linkage ..you need to get the rpm down if it is really 1200 ..it will grind ..
there is no syncros in the lower unit ..just a 'engagement dog " ..
