  #1
Old April 10th, 2005, 12:18 PM
mtrproblems mtrproblems is offline
Default 50 hp 2004 mercury rpm's drop
Motor starts up fine, runs a little roughly at low rpms, but at wot the engine runs perfectly for 5-10 seconds at 4900 rpms and then drops to 3000-3200 rpms and wont run any faster. If you drive in low rpms (800-1000) for 5 min, you can get up to 4900 rpms before it drops back down again. Any idea what's up? Everything is close to brand new and even have a water/fuel seperator installed.
  #2
Old April 10th, 2005, 02:32 PM
JB's Avatar
JB JB is online now
Default Re: 50 hp 2004 mercury rpm's drop
Howdy, problems.Welcome to iboats. I will move this to Merc troubles.
__________________
RED SKY at night. . .
JB
  #3
Old April 10th, 2005, 03:23 PM
bassman283m bassman283m is offline
Is it a 4 stroke? How long have you had it? Has it always done this?
  #4
Old April 10th, 2005, 07:37 PM
Laotzu Laotzu is offline
I have a 1991 50hp that does the same thing. Runs smooth after it drops down to about 3k rpm's...no missing, smoke, purr's like it should, but just won't accelerate. I have been trying to troubleshoot for a while now. Anyone who helps mtrproblems will also help me. Two birds with one stone.
  #5
Old April 10th, 2005, 07:42 PM
Its a two-stroke, had it 3 months. It hasnt always done this. Mechanic has looked at it done a lot of tests, suggested the fuel-filter, it hasnt helped.
  #6
Old April 11th, 2005, 03:39 PM
I think it may be the fuel connector (my terminology may be wrong) where the fuel hose enters the motor that is sucking air resulting in rpms dropping. I'm gonna purchase a new connector and see if that fixes the problem. Hope I may have found a solution to our problem Laotzu.
  #7
Old April 11th, 2005, 04:45 PM
Silvertip Silvertip is offline
When it tends to die off, activate the choke (push in on the key) momentarily. If that doesn't do anything, try squeezing the primer bulb a time or two. If the engine picks up you indeed have a fuel delivery problem. Pickup in the tank, bad primer bulb, fuel connector, fuel pump, to name a few.
  #8
Old April 11th, 2005, 07:56 PM
mtrproblems..how do you know the connector is sucking air?
  #9
Old April 12th, 2005, 07:18 PM
didnt, the connector just felt really loose.Had another mechanic check it, turns out some foreign object was restricting gas flow in the carb.(no idea how anythihng would get in there) Engine runs great now. One of your carbs probably isnt working for some reason.
  #10
Old April 13th, 2005, 07:04 PM
Not it. I had it in the shop and they checked out all the fuel systems and all were ok. Flushed the carbs, etc. I tried a remote fuel source, but still does it. Guess I'll have to take it in again unless someone here can help me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Seapro 225 3.0 rpms drop in rough seas capnrobalo Mercury & Mariner Outboards 10 May 18th, 2005 09:12 AM
50 hp 2004 mercury rpm's drop mtrproblems Yamaha & Suzuki Outboards 1 April 10th, 2005 02:32 PM
1979 200 HP Mercury Black Max sudden drop in RPM/Torque footer Mercury & Mariner Outboards 3 August 26th, 2003 10:04 PM
Drop in RPM's Chicken Ship Johnson & Evinrude Outboards 3 April 10th, 2003 08:52 AM
Drop in RPM's 495v Mercury & Mariner Outboards 3 May 28th, 2002 12:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
