  #1
Old March 19th, 2005, 10:25 PM
murphczx murphczx is offline
Default Oil leak on 2003 Mercury 75ELP
We have a mercury 75 ELPTO 2 stoke on our Rib. When we transport the rib on the trailler, the engine is tilted up. When we reach the end of our journey, usually there is some oil on the inside of the boat - which has dripped from the engine. I have removed the Cowell and the leack does not seem to be coming from the oli tank cap seal as it all appears to be dry.We od not have any leakage problesm when the engine is kept in the upright position.Anyone goy any ideas where to start looking.Thanks
  #2
Old March 20th, 2005, 02:16 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Oil leak on 2003 Mercury 75ELP
Welcome to iboats.Have a look at the foam inside the hood in front of the oil tank. If it is saturated with oil, the cap leaks. Otherwise it's fuel/oil coming out of the carbs when tilted. The gas evaporates leaving oil. It shouldn't leak out under normal circumstances, but bouncing around on a trailer makes it kinda inevitable.You might consider a Transom Saver. That would allow you to leave the motor down a bit with less tilt.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old March 20th, 2005, 03:04 AM
Quote:
Originally posted by WillyBWright: Welcome to iboats.Have a look at the foam inside the hood in front of the oil tank. If it is saturated with oil, the cap leaks. Otherwise it's fuel/oil coming out of the carbs when tilted. The gas evaporates leaving oil. It shouldn't leak out under normal circumstances, but bouncing around on a trailer makes it kinda inevitable.You might consider a Transom Saver. That would allow you to leave the motor down a bit with less tilt.
  #4
Old March 20th, 2005, 03:09 AM
I replaced the cap - still the same problem. Regarding the suggestion around the carbs, whereas this may not be normal ..... is it a problem that will turn into something more significant. I have also found that the oli appears ther even if the boat has been statoenery. However the angle of tilt deffinitely affects whetehr or not oil will appear or not. Any more info would be much appreciated.
  #5
Old March 20th, 2005, 03:30 AM
rodbolt rodbolt is offline
remove the hood. fill the oil tank. tilt the motor full up and have a refreshing beverage and watch where it leaks. the tank seals on some of the inline mercs were iffy. as were the tank vents.
  #6
Old March 20th, 2005, 06:11 PM
cwilt's Avatar
cwilt cwilt is offline
hey murph,i have a 90 with the same situtation. my buddy is a merc mech and when i noticed the the same (though to be ) problem i popped the same question. he told me that "its leaking from the carbs. most mercs do that when they are tilted up. " i haven't had any problems only visual. to be sure yours is the same as mine check where the air box meets with the carbs.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help! 2003 Mercury 5hp chunkachange Mercury & Mariner Outboards 34 June 15th, 2004 07:44 PM
2003 15 hp Mercury bradyt Non-Repair Outboard Discussions 2 December 21st, 2003 06:50 PM
2003 15 hp Mercury bradyt Mercury & Mariner Outboards 2 December 21st, 2003 06:50 PM
2003 40 Hp. Mercury Tin lid Mercury & Mariner Outboards 7 November 6th, 2003 11:49 AM
2003 Yamaha 115 four stroke oil leak zuru Yamaha & Suzuki Outboards 5 November 5th, 2003 04:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
