  #1
Old March 18th, 2005, 04:24 PM
rlindsay rlindsay is offline
Default 1993 25hp Mercury choke
When the choke knob is pulled to depress the primer button, should fuel be seen squirting into the carb throat or is it going directly to the cylinder? I need to know if the plunger is working or if there could be an obstruction.
  #2
Old March 18th, 2005, 10:32 PM
hondon hondon is offline
Default Re: 1993 25hp Mercury choke
It is shooting into the intake manifold and you wo,nt be able to see it.What do you have going on?
  #3
Old March 19th, 2005, 03:12 AM
The problem is difficulty with cold starting. Either my procedure is wrong or there's a problem with the fuel flow. Motor runs great once it starts but it takes 20 minutes of cranking at least to get it going. Your reply was a big help. I've gotten two conflicting opinions from boat mechanics and needed to know. I pump the primer by hand and see no fuel but hear it squirting. I'll assume it's working properly and try again.
  #4
Old March 19th, 2005, 03:56 AM
DavidStonehouse DavidStonehouse is offline
Hello, I have a 25hp 2003 mariner which apparently is simillar to the 25hp mercury.I use the following proceedure to start mine from cold.1. Squeeze the fuel line bulb untill it is hard.2. Pull out the primer knob(situated on the front of the motor)slowly one or two times and leave the knob out.3. Again squeeze the fuel line bulb just to make sure that it is hard.4. On the ignition switch turn the key to the right and press it in this will operate the electric choke. Keep it pressed in and then start the motor.5. Once the motor starts push in the engine primer knob or the motor will stall after a few seconds. .6.Lift up the warm up lever approx no more than1/4 or 1500rpm untill motor is warmed up.Then push it down.I appreciate that every motor or is different even similar models. Hope this helps.
  #5
Old March 19th, 2005, 04:23 AM
Laddies Laddies is offline
It sound like the primer is not working I have found a few of them with dirt or varnish in the check valve to the primer and need only to be cleaned out, while you have the carb off you can hook a gas line to it and make sure it is working before you reinstalling on the engine, don't buy a carb kit intill you check to see if you need one, as they are quite expenceive--Bob
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #6
Old March 19th, 2005, 04:33 AM
DHPMARINE DHPMARINE is offline
Next time the motor is running and warmed up .... pull the choke out.If the motor quits right away,the choke/primer is working.If you do rebuild the carb,purchase the gasket/diaphram set as well as a needle/seat kit.The complete rebuild kit really IS costly.DHP
  #7
Old March 19th, 2005, 06:05 PM
The problem seems solved. Plugs seemed OK but replacing them has definitely made a difference. My starting procedure was also faulty. Pulling out the choke knob to the first stop only advances the timing. Pulling it out even more actuates the primer button. The instructions to leave the knob out at the first stop means the timing is advanced until the engine starts and is then immediately pushed in. Turning the knob clockwise also advances timing. DHB, The advice to pull the choke out once the engine warmed worked when the knob was pulled to actuate the primer. Died quickly, so must be working. Forgot to mention this engine is a converted tiller model. The choke solenoid was never installed. If one can be ordered, I'll get it. The 2003 Mariner does seem to be much like this engine. Thanks to all for the great advice. I understand much better how things are working and surely saved a bunch of money. Good fishing!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1954 25hp Choke solenoid wbeaton Johnson & Evinrude Outboards 4 December 7th, 2006 11:36 PM
9.9 Yamaha 1993 start hard / NO CHOKE ??? fishon71 Yamaha & Suzuki Outboards 4 November 8th, 2005 08:19 AM
Choke Problem, 1983 Mercury 25hp hbaldwin Mercury & Mariner Outboards 1 September 14th, 2002 04:49 PM
25 hp 1993 Evenrude no choke George Corris Non-Repair Outboard Discussions 3 January 26th, 2002 01:36 PM
1993 mercury 25hp electric, 8 hours on it... rebel duck Mercury & Mariner Outboards 1 June 27th, 2001 04:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
