I have a 1990 Mercruiser Alpha One Inboard MCM 2.5L with transom S/N of OC745130 and drive S/N of OD341860 and a 120 hp rating. How do I get a simple instruction to use the drive control, e.g. starting, throttle, acceleration and proper tilting/triming for planing? How do I use the blower properly, e.g. at speed and at cruising? The engine is installed on a 1990 17.1 ft f/g Invader boat.<br /><br />Besides, the swim ladder appears to be submerged for about two inches. Is this normal?<br />When the boat is runing, the boat tilts to the left of the portside, is this normal (I have a slightly bend "keel" on the bottom of the out unit which will be repair later.<br /><br />Is it normal to have a little water at the bottom of the boat below the engine?<br /><br />Thanks
