  #1
Old March 14th, 2005, 11:00 AM
MeanWS6sp MeanWS6sp is offline
Default 200 hp Mercury EFI won't accelerate past 1600 RPM's
Would this be the stator? Its EFI so I'm hoping its not fuel....
  #2
Old March 14th, 2005, 04:03 PM
prolinews prolinews is offline
Default Re: 200 hp Mercury EFI won't accelerate past 1600 RPM's
I would think it would be fuel related before electronics . I have never seen a motor with a bad stator crank. fuel pump filters plugs etc start with the simple stuff first.
  #3
Old March 15th, 2005, 03:58 AM
Kenny Bush Kenny Bush is offline
Better check fuel system first as stated earlier.
  #4
Old March 15th, 2005, 04:07 AM
rodbolt rodbolt is offline
what year 200? the system changed slightly over the years. have you made sure the vapor seperator is actually getting fuel? any other running symptoms? drain a sample from the vapor seperator and check for water.
  #5
Old March 15th, 2005, 04:13 AM
hello again have you done the basics of two stroke tests? compression and spark. verify them first before doing anything else. actually its a basics forALL internal combustion articulated rod desighn engines. its a must. suck,squeeze bang and blow. its worked that way since the 1800's and most likly will past the end of the 2000"s.
  #6
Old March 15th, 2005, 05:46 AM
linmat linmat is offline
I had the same problem with my older 1988 200hp and it was the stator.
  #7
Old March 15th, 2005, 10:14 AM
Wow, thanks for all the responses! I haven't done the compression test, but we've changed the plugs, poured out the filter, I think I'm going to buy a new one today and try it. Apparently the stator has a high end and low end...is that true...
  #8
Old March 17th, 2005, 07:26 AM
Yep, it's true - it was the high end on mine that died.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 130.....Won't Go Past 2200 RPM's flatsmanedg Yamaha & Suzuki Outboards 5 June 20th, 2006 05:05 AM
older Mercury 115 will idle but will not go past about 1500 rpm's Ricnc123 Mercury & Mariner Outboards 20 January 27th, 2006 07:17 AM
Mercury Outboard Won't Accelerate RAR45110 Mercury & Mariner Outboards 3 September 18th, 2005 09:24 AM
Nissan 5HP doesn't accelerate past 1/2 throttle Gi da Joe Honda & Tohatsu/Nissan Outboards 11 April 9th, 2005 05:42 PM
Tach not working past 2000 RPM's (help) bmurray Johnson & Evinrude Outboards 5 July 5th, 2002 07:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
