  #1
Old March 1st, 2005, 10:07 AM
ba_50 ba_50 is offline
Default Mariner (yamaha) 9.9E leaks gear oil out drain hole
Hi again,I've got one more problem with this 9.9 and that is the lower unit oil is going out the front drain hole just above the fill hole when I'm filling it up.There isn't any oil coming up through the drive shaft that I can see. So is there a seal on the shift rod that it could be getting by?If so how would I replace it?Thanks. Bob
  #2
Old March 1st, 2005, 10:24 AM
DHPMARINE DHPMARINE is offline
Default Re: Mariner (yamaha) 9.9E leaks gear oil out drain hole
If you drop the gearcase,and put it in a vice,you should be able to see exacly where it is coming from.DHP
  #3
Old March 2nd, 2005, 03:36 AM
DHP,Thanks for you interest. I do have the lower unit off and when I try to put oil in the top plug hole, it comes out the front drain hole just below the cavitation plate. No oil comes out the drive shaft seals. I know you are supposed to put the oil in the bottom hole but that shouldn't have anything to do with this problem. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Drain hole,Seep hole,water leaking from powerhead JDB123 Mercury & Mariner Outboards 5 January 29th, 2007 11:17 PM
tell tale hole (weep hole) on 1986 Merc Mariner 75 eastshores Mercury & Mariner Outboards 1 May 14th, 2006 06:55 AM
Merc 7.5 gear drain screw leaks! rakos Mercury & Mariner Outboards 3 October 31st, 2005 01:07 PM
Mariner 9.9E leaks gear oil out of small hole on lower unit ba_50 Mercury & Mariner Outboards 0 February 25th, 2005 08:23 AM
Rebuilt Force 120/125 leaks water @ lower sparkplug hole lmoore101 Force & Chrysler Outboards 5 October 1st, 2003 02:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
