  #1
Old March 1st, 2005, 02:29 AM
Nidri240 Nidri240 is offline
Default Mariner 6hp 1996 starting problems
Hello all,I have recently acquired a Mariner 6hp from 1996 which I bought along with a small sailing boat earlier this year. I have seen the motor run and know that it has only run for about 100 hours (laid up for a number of years).Here comes the problem! I can't get the thing started!I have checked the sparks, both plugs OK. I have stripped down the carb, no signs of any varnish or gumming up. Fuel is getting to the carb, no blockages anywhere in the system that I can see.The choke primer appears to work fine.Before my arm falls off, can any of you knowledgable souls help me out with any suggestions?In anticipation......
  #2
Old March 1st, 2005, 03:42 AM
jeff15svt jeff15svt is offline
Default Re: Mariner 6hp 1996 starting problems
how old is the fuel ? have you tried a light amount of starting fluid ? also you said the plugs looked fine, BUT have you put a spark tester to the motor yet ?
  #3
Old March 1st, 2005, 04:25 AM
the fuel is probably quite old, actually it's over 12 months old. hmmmm perhaps I should get myself to the fuel station!I've not actually tried starting fluid - I have heard that it can damage the motor. Is this true?
  #4
Old March 1st, 2005, 04:53 AM
DHPMARINE DHPMARINE is offline
Please don't use the starting fluid.I should put it in ALL caps,but I try not to raise my voice here.12 Months is pushing the age of the fuel a bit,but when you say the choke primer appears okay,how do you know ?If it is electric choke,have you tried using manual choke ?DHP
  #5
Old March 1st, 2005, 05:05 AM
It is a manual choke. When the knob is pulled, a small diaphram is pressed which squirts extra fuel into the carb. I have checked this diaphram and there are no rips / tears in it.I will not use starting fluid.
  #6
Old March 1st, 2005, 05:44 AM
Only other thought I have at the moment.... when you pull the choke knob out,and the plunger goes down,does the link back to the timer base advance?I don't have the specs,but it should be increasing the timing,to give you a faster idle when choking.DHP
  #7
Old March 1st, 2005, 08:43 AM
yes on a 2 stroke starting fluid should not be used if you dont know what you are doing, but if you are careful with it it can work and be a big help. use it carefully and it can help, only problem is people misuse it, thats why it has a bad rapi work at j&r marine as a mechanic, and i firmly believe it can help when used right
  #8
Old March 2nd, 2005, 08:33 AM
jeff15svt, I enjoyed your post,and also use lots of chemicals in boat repair.But somewhere I missed info on the starting fluid,and want to know more. How do you guys apply it ?DHP
  #9
Old March 2nd, 2005, 10:32 PM
One thing I don't understand about starting fluid is this: motors are designed to be started from cold without the use of ether or any other additive. If the motor won't start, then there is something wrong somewhere. Surely the use of starting fluid will just hide that fault. In which case, if I start using it I will have to continue using it.I don't think I'm prepared to do this on an engine with so few hours on it. I need to find the reason why the engine isn't able to start and solve that.Giles
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Mariner 150 carb problems ????? apextrail1 Mercury & Mariner Outboards 8 October 17th, 2006 05:25 PM
Starting Problems 1996 25hp Merc imported_Hawkeye Mercury & Mariner Outboards 1 September 24th, 2006 01:59 AM
starting problems with mariner 90 snookered171 Mercury & Mariner Outboards 7 November 25th, 2005 12:04 PM
1996 60h mariner trouble starting marinerman Mercury & Mariner Outboards 4 June 21st, 2004 12:47 PM
1996 johnson 50 horse starting, idle problems lake hopeless Johnson & Evinrude Outboards 1 May 17th, 2003 07:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
