Re: Do I need to replace ALL seals on LU?
Hi again,<br /><br />To pressure test you take the LU off (that's the first step for whatever you do), as you guessed, find a way to replace either the vent or drain plug with something that will hold air. If you have one of those little pumps for pumping oil into the LU, you can borrow the end that screws into the fill plug to use (with the length of tubing), or in a pinch I've used a small rubber stopper and run fine stiff tubing through a hole I drilled through the stopper. Then use something (I use a syringe, but bike pump would also work) to pump air into the LU. DON'T OVER DO IT. A shop will usually pressure test with 10 psi I think. If you use more, you could blow out otherwise good seals. T-ing on a pressure guage to your pump/syringe line is helpful, especially later to confirm that the unit is holding pressure well. Since you know you have a leak, yours won't hold pressure so if you have a guage attached, you'll see the pressure run down right away. Then keep your tubing/pump contraption attached and submerge the LU in water... I've used a bathtub if motor is small and wifey is not watching, or a little "kiddie pool" for my 150 hp (big cav plate). Once underwater, give a pump or two of air and see where the bubbles come from. Fix leaky spot (sometimes find something surprising - see below) and then pressure test again. Now the LU should hold 5-10 psi. This is where you need to be careful not to overpressurize and where a having a pressure gauge in your tubing "contraption" is needed... leaving a foot or two of tubing length between the LU and the pump/pressure gauge is helpful, since you don't want to submerge those with the LU.<br /><br />Just this week doing a pressure test kept me from pulling seals that are fine on motor that is new-to-me... turned out it was a weird leak from a screw hole that looks to have been drilled all the way through when it should've been blind. <br /><br />Anyway... good luck!<br /><br />Brent
