Hey... I'm new to this site... but, it's AWESOME!! I have a Mercury 200 Black Max... Model #1200422GD Serial # OC150739 When I'm running above idle speed.. I have a good stream of water out of the "pee-hole". When I'm idling.. It comes out sort "erratic".. (stream, stop, stream, stop). When I run at high speeds for a long time.. the engine temperature (according to my gauge) stays in the "normal" range. When I come back down to idle.. the temperature gauge goes up and sometimes after extended periods of high RPM running and back down to idle speed... I get hardly any water out of "pee-hole" and sometimes even STEAM out of the hole!! You can hear the steam whisps while idling! Now... when I'm at home and I flush the motor using the muffs... I get a pretty good stream of water while idling... The temperature gauge is even lower... and there's a GOOD stream coming out of the center of the prop. There's also a good spray from the "exhaust nostrils" on the motor whether I'm on the muffs or under way. Some people have told me the water temperature I run in here.. (Gulf Coast Alabama.. sometimes 87 degrees F and UP in the summer!) is just not too cool enough for the motor to be properly cooled after high RPM running and then quickly back down to idle speed. Maybe the low water pressure and fairly warm (feels like bath-water!) water temperature can't cool the motor fast enough when returned to idle speed after a hard, extended running? If I keep idling at a "little higher" than idle speed engine speed... The temperature gauge will eventually come on back down to "more" normal. It has never over-heated... Just runs more warm than I'd like it to.. Especially after those hard runs. ALSO.. My motor has no thermostat... Hasn't had one for years. Would that make that much of a difference? ALSO.. When you first start it.. (In or out of water.. ON or OFF muffs.. I mean..) If you keep it idling.. It will idle all day long nice and cool.. It's only when you run it hard then come back to idle quickly does it run "sort-of" hot. Is all this normal for my water temperature I run it in? Sorry so it's such a long post.. Thanks for your help guys!!
