  #1
Old February 13th, 2005, 07:15 AM
ba_50 ba_50 is offline
Default Mariner 9.9E fuel pump
Hi,I've got around a 1985 9.9E Mariner fuel pump problem. I replaced the inside diaphraghm and gasket. With the pump off the carb and the fuel line attached I try to pump gas through it. It has to be forced to go from the fuel line side to the other half of the pump. The outside diaphragm is stiff, but I don't know if that is what is blocking the flow or the metal tab.Do you think it is the diaphragm or the tab? The metal tab doesn't look damaged. Any other possiblities? The gas isn't getting to the carburator. Thanks.
  #2
Old February 13th, 2005, 09:00 AM
Laddies Laddies is offline
Default Re: Mariner 9.9E fuel pump
It sounds like the diaphram is not in right and blocking the fuel flow
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old February 13th, 2005, 09:41 AM
rodbolt rodbolt is offline
the metal tabs are flow check valves, if they are not there it wont pump.
  #4
Old February 14th, 2005, 01:09 AM
The D.... is crinkeled sit might be blocking it. The metal tab is attached but seems tight, even though it isn't damaged. I'll take out the D... and see if the fuel goes through then. Thanks.
  #5
Old February 22nd, 2005, 02:10 AM
I put the other diaphram in and it worked fine. Problem solved. Expensive, but solved.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
97 Mariner 25hp..fuel pump?? Harker Mercury & Mariner Outboards 5 July 29th, 2009 10:36 PM
115 Mariner Fuel Pump dansndais Mercury & Mariner Outboards 2 March 14th, 2006 03:13 PM
97 3cyl Mariner Fuel Pump & Oil Injection Help captaingrubby Mercury & Mariner Outboards 1 August 29th, 2005 04:21 PM
Mariner fuel problem...fuel pump? LubeDude Mercury & Mariner Outboards 3 May 16th, 2005 04:56 PM
9.9 mariner fuel pump assembly buzzroid2001 Mercury & Mariner Outboards 0 July 5th, 2003 06:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
