I have a problem with my 2002 merc 4 stroke 90 horse.I purchased new.First year fine,last year would smoke on restart after running for 10 minutes or so.The initial start up at ramp will not produce smoke?Only when the motor is hot?I shut down to fish for 20 minutes or so and retart.The motor will blow blue smoke,large amount of carbon deposit on prop.
Had the dealer change the oil at required time.With only 2 hours running time with the new oil the oil seems to be black and thinner?Hope someone knows what is going on with this unit.Otherwise the power is fine and starts first turn of the key.
Dealer says carbs are not burning all fuel and on start up and needs to adjust carbs.Could it be something this simple?Worried as only under warranty for 6 more months.Thanks for any help.
