  #1
Old February 1st, 2005, 02:33 PM
jakeboomer jakeboomer is offline
Default Mercury 25 - Cracked drive shaft housing
I have a 1988 mercury 25 horse - short shaft. I bought it a couple months ago and didn't notice cracks in the shaft housing right above the lower unit. I knew the motor seen shallow water, but the compression was great, and there was no water in the lower unit. Last week I hit a submerged dike and bent the prop shaft. Very unlucky. While pulling the lower end, I noticed the cracks were much worse than I thought. One of them goes from the front foot of the housing across to the other side. My question is this. Can this be welded, or does anybody know where to start looking for a used shaft housing? How about locations for used prop shafts? I have a manual, and can be pretty handy with a wrench if needed.Any recommendations would be appreciated. When this happened, I almost tossed the motor and headed out for a new one. The problem is that the motor runs so well. I rebuilt the carb and it starts in one pull every time. It has excellent compression to boot. Thanks again.
  #2
Old February 1st, 2005, 03:24 PM
marinegrh marinegrh is offline
Default Re: Mercury 25 - Cracked drive shaft housing
the mid section that you are refering to can be fixed, as long as the cracks are small enough, one method of fixed a metal crack is to drill on either side of the crack to prevent it from increasing in size, then you can have it welded, but by a good welder only, you dont want some joe burning it to hot and making mush out of it, there is some concerns i would have though and that would be where are the cracks located, are they around where the bolts thread in, are they through the exhaust area etc...you should have no problems thought as its only aluminum....the propshaft, you may not want a used one, you have to worry about condition and wear on it...try mercurys parts express and price em out.....heck sierra might even make a aftermarket one....good luck and keep us infoed
  #3
Old February 2nd, 2005, 10:31 AM
Well I pulled the drive shaft housing off last night, and the front section (where the two front lowerend bolts connect) finally broke off. The crack was much worse than I had anticipated. I don't believe it's worth welding, so I need a new housing for a short shaft. Preferably, I would like to purchase a used one, since i still have a lowerend to rebuild. Does anybody know of a good junkyard for Mercury motors. I am sure somebody will have a dead powerhead or lowerend attached to a solid housing I could purchase.Thanks,jakeboomer
  #4
Old February 2nd, 2005, 01:15 PM
rodbolt rodbolt is offline
email me at rodbolt40@ yahhoo.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
re sealing drive shaft housing alpha gen 11 sonofjohn Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 15th, 2006 08:29 PM
Cracked driveshaft housing on Mercury 200 dcfrank3 Mercury & Mariner Outboards 3 April 14th, 2005 09:35 AM
Drive Shaft housing leak stephenp Force & Chrysler Outboards 6 November 7th, 2004 03:32 PM
Help removing drive shaft, bearing housing johnson-liner Johnson & Evinrude Outboards 2 August 2nd, 2004 11:31 AM
Drive shaft housing frozen Ron Maire Mercury & Mariner Outboards 2 February 10th, 2004 07:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
