Re: 2001 Mercury Outboard 225 EFI Saltwater Series excessive smoke
you may want to have an oil consumption test done, that motor as you call it, does like to smoke a bit especially if it has been sitting awhile, however, once warmed up and blown out, it should go away and exhaust the normal two stroke smoke, but not so much as to ward the skitos away...a good dealer should be able to do the consumption test for about 50 - 75 bucks and tell you what the smoke is all about,.good luck
