yep i neglected to replace or even clean out the fuel /water seperator and it went into the carbs....i have a 200 merc .. 1988 ..i replaced the seperator with clear bottom one so i can see if theres water.....and replaced the small filter just before the fuel line to the VRO.. could there still be water in the bulbs?? also i put water remover in the fuel and can at least get it to idle .... but .. now the fuel enrichment valve does not seem to be working ,, thats the primer or choke device i think.. <br />actually i know the valve works but the system is not spraying fuel into the carbs..all hoses to the valve are clear i can blow into em... stumped in NY
