  #1
Old January 23rd, 2005, 10:17 AM
Big Ears Big Ears is offline
Default Running in a 84 Mariner 75hp after a Rebuild
3 days to go till I pick up my boat with a rebuilt motor!My plan is to try to spend around 15 hours running it in over 3 - 4 days. The first 100 litres will be at 25/1 and the plan is to vary the rpms every 5 - 10 mins.I thought it might be a little like a car, that is the best way to run it in is continuos versus stop/start. In the past this has meant I would go for a 5-6 hour blast up the highway and with the boat I'm planning to do a few trips up and down Sydney's amazing Hawkesbury River.Any other suggestions / tips ?
  #2
Old January 23rd, 2005, 10:54 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Running in a 84 Mariner 75hp after a Rebuild
Idle it for quite awhile at first. Go out gently for a half hour. Then tromp it, get on plane, then back-off to 3/4 throttle and run it around there but varying it a bit now and then. After the first hour, try full throttle for a few short bursts. If it holds, you're probably good to go. Just avoid long periods of full throttle for the first tank or two. Babying it too much can do more harm to a 2-stroke than pushing it to it's limits.After the first run, check the sparkplugs. They should burn evenly.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old January 23rd, 2005, 10:59 AM
rodbolt rodbolt is offline
hello here is a paragraph from the manual without auto blend fuel oil ratio is 25-1 for the first 30 gallons(113.5 liters).operate motor at varied throttle settings not to exceed 1/2 throttle.2500-3500 rpm for the first 10 hours.after the first 10 gallons (37,8 liters) outboard can be run at any speed. however, avoid sustained full throttle operation until all 30 gallons of 25-1 have been consumed this is from page1-12 of manual #90-86134--4 covering 75 hp inlines from seriel # 4590512 and up.
  #4
Old January 23rd, 2005, 02:08 PM
Thanks Rodbolt, appreciate you and Willy replying.
  #5
Old January 23rd, 2005, 03:42 PM
rayjay rayjay is offline
I would expect that the mechanic would have already ran the motor at least 20 or 30 mins in a test tank.
  #6
Old January 27th, 2005, 12:35 PM
Well, 3 days has passed and believe it or not, it still isn't ready !i rang yesterday to make sure all is AOK for pick up the following day and there's been a hitch.2 of the rings are oversize by 30 thou and he's hoping the proper rings will arrive in time to finish the motor today. I can't help feeling like this is a convenient excuse and he's had a few easy jobs come in. He's had the boat for 19 days now, one would think he'd be trying to do it as quickly as possible to make room in the workshop for the next customer's boat. He'd also have a happy customer ( me ) who would tell all and sundry how happy I was with the service. What I don't understand is the total lack of customer service. IF it was my business, I would inform my client as to the status of his repair, not wait for the customer to call. I would also ensure that the customer at all times felt that he was important and I valued his decision to use my services. I was in business fror myself for 20 years and never spent a dollar on advertising as my customers did it for me. I guess if your in a position / business where there isn't alot of competition, you can afford to have the attitude my mechanic has. Hopefully, I have misjudged him and He'll be calling this afternoon saying the motor is ready to go, but I'm not holding my breath.
  #7
Old January 30th, 2005, 10:24 AM
Well I have cooled down a little since the last post! Still not finished for the weekend but I did a few chores around the house and my better half is very happy while I undertook a little diversion therapy. On top of that, the weekend produced 2 overcast days so I haven't missed any real quality time on the water. I'm, wondering if my mechanic read this as on Fri afternoon I had a call from him letting me know that he has a couple of hours left tofinish off the job and I should pick it up today. I was very happy I didn't have to call him this time and with a lil luck, I won't need to see him unless it's to watch him race or to do a little warranty work.
  #8
Old February 3rd, 2005, 04:28 AM
ufm82 ufm82 is offline
Do yourself a favor on the break-in. This sounds very unorthodox, but I'll swear to you that it works and you will see better results and power out of that new engine. Take it out for the first time, let it warm up completely and then firewall it. Seriously, open her up full bore and let her climb up to WOT- then shut down and coast. Return back to idle and do that again. The science here is how rings seat. Rings and cylinders will wear to match each other. When you "baby" an engine and don't run it hard, the rings don't get enough pressure against them to seat themselves fully. You will get 80% or 90% seating. When you run it hard and maximize the pressures in the cylinders, you get a much higher chance of achieving 100% seating. Take any engine apart that has been "babied" and look at the pistons. See the brown stains down the sides of the piston, past the rings and on down? That's blow by and it is caused by a poor ring/wall seal. That doesn't happen when you break them in hard and get 100% contact. Your power goes up, your fuel consumption goes down and the engine itself will last longer because you're not getting as much burnt fuel by-products in the crankcase. This isn't BS- it's been documented and researched. I have torn down probably a 1,000 engines over the years and hands down, the worst machines I found were those driven by "little old ladies" that never really opened up the throttle. Low mileage vehicles that needed engines because of severe oil useage or excessive blow-by, causing high crankcase pressures and seal/gasket failure. So take it out and run it hard- you'll find that it runs much better later in life. UFM82
  #9
Old February 6th, 2005, 10:23 AM
UFM82, that's exactly what my mechanic said and I have taken him at his word.After taking it back twice for little gremlins to be sorted, the motor is running like a new one and I'm very happy with its performance so far. My mechanic took it out on Friday and did exactly what your describing, we were dancing over the top of some 12 - 24" waves at 40 miles/hour .This guy races F1 superboats ( 300+hp) and he sure knows how to read the water / swell.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2003 mercury 75hp not running right prodeep Mercury & Mariner Outboards 13 April 5th, 2007 10:30 PM
76 Johnson 75HP - Rebuild Problems dhym Johnson & Evinrude Outboards 4 September 22nd, 2005 10:46 AM
75HP evinrude running rough, bad gas? markheth Johnson & Evinrude Outboards 4 July 26th, 2004 07:10 PM
thanks! '63 75hp Evinrude now running mellocj Johnson & Evinrude Outboards 0 May 15th, 2002 04:54 PM
1963 75hp evinrude running mrk_cdk Johnson & Evinrude Outboards 0 July 5th, 2001 09:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
