  #1
Old January 20th, 2005, 04:59 AM
jorwalke jorwalke is offline
Default 1996 200 HP Mercury Lower Unit or linkage Adj. Problem
I just purchased a used boat and did not notice this in the test run because I did not run it in reverse very hard. The motor rus great in the forward direction with no problems. When you go to put it in reverse the motor gears appear to grind or roll a little and then it goes in to gear. Not very hard to get in reverse though. The motor the rus in reverse farely well until you torque down on it by appling more throttle and then the lower unit starts thumping real hard with it continuing to go in reverse. I Sounds like a gear may be missing a tooth but I draineed the lower unit and found no signs of metal. Did not want to pull the unit if it could be an adjustment problem. Any thoughts would be appreciated. Thanks
  #2
Old January 20th, 2005, 07:16 AM
robalofish robalofish is offline
Default Re: 1996 200 HP Mercury Lower Unit or linkage Adj. Problem
Are you shifting with a quick motion or just easing it into gear? Proper way is to move lever quickly into gear. Other than that get a manual (I like Mercurys) and it will describe the adjustment procedure.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
67 Mercury 9.8hp lower unit problem gmarshall43 Mercury & Mariner Outboards 5 October 26th, 2004 01:07 PM
Tohatsu M50D linkage or lower unit problem ba_50 Honda & Tohatsu/Nissan Outboards 1 November 5th, 2003 07:47 AM
On a 1996 Mercury 125hp/rebuilt lower unit A$$ backwards controls Mercury & Mariner Outboards 1 July 29th, 2003 06:35 AM
Mercury '99 90hp lower unit problem johnswift420 Mercury & Mariner Outboards 0 June 24th, 2002 05:55 PM
Mercury Lower Unit Problem kris_merc Mercury & Mariner Outboards 2 April 10th, 2002 10:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
