  #1
Old December 13th, 2004, 03:04 PM
Benzie Benzie is offline
Default Mercury alpha-one drive .shift re-assembly?
i split my drive to replace water pump .. all is done and good ...however i believe the shift rod in the lower unit got turned some .. how do i re-index it to forward position so when i put the two halves together and re-install. my forward and reverse will work properly ??
  #2
Old December 13th, 2004, 03:36 PM
andrewkafp andrewkafp is offline
Default Re: Mercury alpha-one drive .shift re-assembly?
Is an Apha 1 a sterndrive ?Normally, you would drop L/U, turn lower shiftshaft to neutral, put shifter in neutral an re-assem. I would guess the the Alpha 1 would be same principal.
  #3
Old December 14th, 2004, 01:38 AM
DHPMARINE DHPMARINE is offline
Alpha 1... put remote control in forward.turn lower unit shift shaft clock-wise (while turning propshaft counter-clockwise).now install.Note that if you happen to turn the prop,or propshaft even slightly clock-wise,the shift shaft goes to neutral.DHP
  #4
Old December 14th, 2004, 02:51 AM
JB's Avatar
JB JB is offline
Moving to Mercruiser troubles.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Alpha 1 Generation 1 Trim cylinder assembly rjrjs Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 March 30th, 2007 03:59 PM
alpha 1 upper / lower assembly tystick Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 September 4th, 2006 12:58 AM
Mercury Alpha One Throttle assembly diagrams??? sanathe Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 31st, 2005 05:18 PM
Mercury alpha-one drive .shift re-assembly? Benzie Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 December 19th, 2004 03:20 AM
Alpha Gen 2 Drive on a Gen 1 Transon Assembly qystan Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 October 17th, 2004 04:43 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
