What size propeller is this?
sloopy
Hi guys,<br />At the marina I work at we have a shelf of "slightly used" propellers. One of the propellers has no size printed on and has been bugging me for over a year. The propeller is a 3 bladed aluminum Michigan with 031016 printed on it. It looks like it would fit an engine under 40hp. <br />Thanks for your help
sloopy
Re: What size propeller is this?
Does anyone know what size this is?
TwoBallScrewBall
Found this using Google:<br /><br /> 95844 031016 10-5/8" RH 12" Aluminum 3-Blade Propeller Each $105.41 See Item
ivar
... and fits the following Chrysler/Force engines according to my michigan catalog:<br />40, 50 HP 1995-98<br />70 HP . .1991-95<br />75 HP. . .1996-98
sloopy
75hp... that little thing?<br /><br />Thanks guys :)
roscoe
Yep, that little thing.<br />Bet it has 13 splines inside.<br /><br />The Force 70-75 uses an old Mariner/Mercury lower unit, that was origianny made for the 40-50-60 motors.<br /><br />It really ads another hp limiting factor into my 70hp Force, as the prop is limiting the performance of the already under performing Force.<br /><br />You mean you've had a marina job for a year and you aren't offering us any deals? :)
