  #1
Old November 8th, 2004, 09:58 AM
Mnemonic Mnemonic is offline
Default 60HP Mariner/Mercury starting probs
Sorry to make another thread, it is a bit different than the other one.. So today i pulled the brand new NGK plugs i had in there to see if they will tell me what is going wrong with the motor (It starts on high idle, and key is pushed in (priming), but dies after i take prime off)..Plugs 1 and 3 look fine, but plug 2 looks as if it was cold fouled by the looks of the picture in my service manual..I am not sure what this means, but i am thinking the carbs need to be decarbed.... I think, but the can of decarbing stuff says to have the motor on while doing it... I cant keep it running that long to do it... Please advise, i want to get this thing normal running enough to winterize it so i dont have to deal with it next season.Thanks,Dan
  #2
Old November 9th, 2004, 05:11 AM
Default Re: 60HP Mariner/Mercury starting probs
anyone?
  #3
Old November 9th, 2004, 10:10 AM
I think i found the problem.... #1.. I think i had my earmuffs hooked up to the exhaust exit.... are you supposed to hook them up to the holes in the front of the lower unit or the holes above the prop?#2.. I pulled the fuel filter that is the last step before the fuel goes into the carbs. Guess what color it was? Yellow. If i am not mistaken it should be a blueish color if the oil was mixing, no?If this is correct, and the color of the fuel in the fuel filter should be blue, that means this motor is not getting any oil!Let me know if this is right please
  #4
Old November 9th, 2004, 08:46 PM
orca orca is offline
G,day, What model motor do you have? The muffs should be over the holes in front of the prop not above the prop.
  #5
Old November 10th, 2004, 03:41 AM
Its a 1987 Mercury/Mariner 60HP
  #6
Old November 10th, 2004, 04:31 AM
jimalsk jimalsk is offline
Are you mixing the gas and oil 50:1 or is the motor, oil injected? If it is oil injected the oil goes nowhere near the fuel filter. It is injected into the motor via the carberators. Chance's are your carbs are in need of cleaning which involves taking them apart cleaning and rebuilding them. To decarb you are removing the carbon buildup in the motor. Do you have any manuals on your motor?
  #7
Old November 10th, 2004, 05:28 AM
the motor is oil injected.... I took out the plugs this morning and the threads have a bluish look to them, so the motor is getting oil.I do have a manual, But i dont know if i am really advanced enough to rebuild my carbs... looks pretty complicated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner / Mercury 60hp 2 stroke elpto khc1970 Non-Repair Outboard Discussions 3 September 13th, 2005 03:57 PM
Starting by electrics probs on Mariner 30 richandali Mercury & Mariner Outboards 0 June 24th, 2005 02:24 AM
Starting Procedure 87 Mercury 60Hp hilge Mercury & Mariner Outboards 3 June 23rd, 2003 10:08 AM
86 Force Starting Probs. JCSuperman Force & Chrysler Outboards 0 June 19th, 2003 06:09 PM
1983 Evinrude 60hp multiple probs sailor_turned_stinkpotter Johnson & Evinrude Outboards 2 January 19th, 2003 11:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
