Re: ONE CYL.NOT FIRING
No fire on one cylinder: Since this condition can be caused by the opposite switch box (pack), disconnect the white/black jumper between the packs and retest. If the dead cylinder starts firing, replace the pack that was firing all three cylinders. As a verification, swap the trigger and spark plug wire to the cylinder closest to the dead cylinder, (i.e., if #1 is dead, swap the brown trigger wire with the white one). If the problem moves to #3, replace the opposite power pack (switch box). If #1 is still dead, swap the green and green/white coil wires. If the problem moves to #3, replace the power pack (switch box). Please remember to put the trigger wires in the correct order after you finish.
