  #1
Old October 25th, 2004, 09:00 PM
kd4vpq kd4vpq is offline
Default Mercury 150 coils/stator?
I have an 84 or 85 Merc 150 Black Max ser# 6409624. I developed a water jacket leak on thestarboard bank...engine started skipping erraticly. Got home pulled cowls and coils were wet. Dried coils out, replaced water jacket gaskettook it out the next day...idle was a little rough but ran fine from 1200 to wot(5200).I fished all day, came home was running motor to flush out salt water...maybe 5 mins at idle then started skipping really bad. Checked plug wires with test light, the two top coils on starboard bank were not firing. My question is, could both coils have gone out at the same time or am I looking at a new stator? And if so how hard it stator to replace?
  #2
Old October 26th, 2004, 04:57 AM
rodbolt rodbolt is offline
Default Re: Mercury 150 coils/stator?
hello usually a staor failure will take out an entire bank. the triggers fire in pairs but I think on opposite banks. I would carfully test the coils. if the got wet inside they will arc internally. try swapping them with a known good bank and see if the problem moves with the coil. good luck and keep posting
  #3
Old October 26th, 2004, 05:03 AM
KCLOST KCLOST is offline
Switch the stator leads that go to each switch box. At the top of each box there are two wires you need to switch from one box to the other. One has a Red and a Blue, the other has a red/white and a blue/white. Switch them from one box to another. And retest for spark. If the no spark condition moves to the other bank, you have a bad stator... If it stays the same you either have a bad switchbox or coil(s) problem.rodbolt is correct though, only two cylinders not firing most likely is not a stator... But it's an easy test. Let us know what you find, and we can go from there....
  #4
Old October 27th, 2004, 05:36 AM
Manatee,Did you find out anything????
  #5
Old October 29th, 2004, 09:31 PM
Quote:
Originally posted by KCLOST: Manatee,Did you find out anything????
I finally got the chance to mess with it today. I switched places with coils...same cyls still not firing...switched wires on switch boxes...no change...called a local repair shop that happened to have a used switch box for 50 bucks. Bought it put it on and now only one coil isnt firing (#1 cyl) top coil same side. So I changed places with the swich boxes...#1 cyl coil still not firing.All others are firing strong. Even switched places with plug wires. Any suggestions?
  #6
Old October 31st, 2004, 05:06 PM
Okay, I have done some more checking. I disconnected the white jumper wire between the two switch boxes and checked resistance on each box by going from jumper wire post to engine ground. Starboard box(cyls 1,3,5) reads 14.88 ohms(original box)This was originally connected to the port bank and worked fine there. Port box(cyls 2,4,6)reads 14.05 ohms(used box from repair shop)Tried this box on starboard bank first and still no fire to #1 cyl....left jumper wire disconnected and started engine. Still no fire to #1 cyl(coil has already been ruled out as culprit)Could difference in bias resistance be causing the problem or could it be the trigger? We also ruled out the stator by switching wires on boxes.The only other thing I know to do is pull flywheel and take a look for obvious signs of damage.
  #7
Old November 1st, 2004, 06:47 AM
Did you completely switched the boxes (removal of all wires from one box to another) also...?If so, and no change, it sounds like a trigger problem, since you confirmed it's not the stator by just switching those leads from one box to another...
  #8
Old November 1st, 2004, 12:17 PM
Quote:
Originally posted by KCLOST: Did you completely switched the boxes (removal of all wires from one box to another) also...?If so, and no change, it sounds like a trigger problem, since you confirmed it's not the stator by just switching those leads from one box to another...
Yep, I switched all wires on both boxes still no change. Ill check resistance on trigger wires and get back to you. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Mariner 75 No spark at any of 3 coils jmburock Mercury & Mariner Outboards 2 April 5th, 2007 08:46 PM
How are the Coils connected onto the Stator Plate? SeaKing15hp Force & Chrysler Outboards 1 August 10th, 2005 10:14 AM
Does my Mercury 1968 20 motor have coils? ba_50 Mercury & Mariner Outboards 1 September 1st, 2004 09:31 AM
Loose coils on stator? Musky14 Johnson & Evinrude Outboards 6 June 29th, 2004 07:57 AM
Stator seems OK ,coils don't doctoroldsmobile Mercury & Mariner Outboards 3 March 18th, 2002 06:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
