I'm in the process of rebuilding the carbs and fuel pumps on this engine (1963 Merc 1000). In the lower pump (the one where the fuel line from the quick connect enters), both check valves are oriented in the same direction. Is this correct? The motor did start before I disassembled the pumps and carbs, but I didn't take it above a fast idle (on muffs).<br />Thanks.
