Re: remove flywheel from 1970 80HP
When you use a flywheel puller,,<br />1) it is usually a 3 bolt config. The flat part is on the bootom. Put all the bolts in the flywheel bolt places through the bolt holes in the top assembly. Damn tech terms.<br />2) tighten the bolts by hand evenly.<br />3) The center large bolt on the flywheelpull should be lightly torgue down on the center flywheel(on the motor) middle bolt round recess.<br />4) As you evnly tighten each bolt.........evenly ..a turn by half at a time,,,Tap with a rubber hard mallet on the top piece of your fly wheel puller. Be rady as the magnet in the stator area is strong asnd it wiil jump when it pops free.<br /><br />It is not rust that makes pulling a flywheel hard. Opposites attract and the magnets are strong . I aint pulling a 200's without a spotter...lol. You wanna do it ....suree
