  #1
Old September 5th, 2004, 03:43 PM
stocky stocky is offline
Default Mariner 150hp v6 (early 80s) piston
Just rebuilt the old girl after top port side cylinder popped a ring. Took it out on the water for its first run and went beautiful for approx. 15 min. then a loss of power. Took it home and pulled the plugs and the cylinder I repaired aint going up and down (DOH).I checked the rods before putting back together but could this rod have been fatigued from the previous episode.Also should the short tube that runs out of the water pump and connects with the hose running down the leg have a hole in it approximately .25".Thanking you in advance
  #2
Old September 6th, 2004, 02:49 AM
Winger Ed. Winger Ed. is offline
Default Re: Mariner 150hp v6 (early 80s) piston
#1 piston doesn't travel?You're lucky there isn't a new hole in the block to look into and see why. I hate to be the bearer of bad news, but bro. you need to clear off the work bench for another tear down of that powerhead.///The hole in the water pump body; it is to secure a old style rubber gromet that holds the metal tube running down inside the mid-case in some applications. If your water pump body doesn't have a gromet (new ones will work, but don't have the little 'nub' that fits in the hole), or 3-4" plastic tube that guides the metal tube into it--you've got trouble. that is what seals the water coming out of the pump and sends it up through the 1/2 inch or so metal pipe to the powerhead for engine cooling. If water isn't coming up (under pressure) from the pump into the powerhead, but rather is just blowing out into the mid section and then finding it's way out the prop hub with the exhaust gases, that would be a good place to look and see why you're blowing up or burning out the powerhead.If you don't have a real firm pressure of hot water coming out the peeee hole or bypass vent--within a few seconds of the engine being started, that may well be your problem.Something I've done more than once was to just miss getting the metal tube set into water pump body. I caught it before I blew an engine--- but its easy to do never-the-less.
  #3
Old September 6th, 2004, 07:36 PM
Thanks Winger Ed. Regarding the water pump, could I wrap electrical tape around the pipe to stop water escaping.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Johnson 150hp rust in cylinders & piston damaged TNBassManCKV Johnson & Evinrude Outboards 4 December 13th, 2005 02:39 AM
Early model 40hp 2Stroke cyl Mariner PACERll Mercury & Mariner Outboards 2 March 21st, 2005 01:33 AM
Mid early 80's Mariner 20 Barry the Limey Mercury & Mariner Outboards 1 March 11th, 2005 08:41 AM
1986 150hp scored piston murcury monsen Non-Repair Outboard Discussions 0 July 8th, 2003 08:51 PM
early/mid 1980's 15 HP Mariner won't idle Case Mercury & Mariner Outboards 4 November 27th, 2001 02:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
