  #1
Old August 20th, 2004, 08:53 AM
olyerickson olyerickson is offline
Default Temperature Sensor, 1990 60hp Mercury
I suspect that this is where I discover yet again that what I'm looking for is another add-in (like the trim sender...)I'm not finding the wire for the temperature sensor on my 1990 60hp Mercury, which I suspect is because there is none. I see "temperature switch" but not a *sensor* wire (that I can hook to my gauge). What should I be looking for? Thanks!
  #2
Old August 20th, 2004, 07:07 PM
KCLOST KCLOST is offline
Default Re: Temperature Sensor, 1990 60hp Mercury
You probably only have the overheat switch... It should be installed underneath the top cylinder plug.... Held in place with a bracket and two bolts.. Either that or the temp sender will be located in the same place...Most likely you only have an overheat (temperature switch) on the motor now...There are other options, but let us know...
  #3
Old August 22nd, 2004, 04:13 PM
Yup, it is pretty-much as you describe: there is a tan wire coming from some kind of inset part, probably the temp switch, right next to the top plug. The wire goes around to the right, to a plastic part (looks like a one-contact terminal block), where it meets up with the tan (?) from the main part of the harness. So where would an add-in sensor go? I know what it will attach to! John
  #4
Old August 22nd, 2004, 05:42 PM
Your options are simple and complicated... Depending on what you want to measure....If you want to measure metal head temps, you're going to have to find a spot that will allow you to insert the sensor to a point that it will make contact with the head.... That's not easy, and I wouldn't go that route...If you want to measure water temps, you can access the water lines past the t-stat... Or, even better, look for a plug at the top of the block (behind the flywheel). You can remove that plug and with the proper fitting, the sensor can be installed there... One wire from the sensor will run directly to the guage...Either way, you're gonna need a sensor for the guage you have...
  #5
Old October 18th, 2004, 06:33 AM
So, Mercury cylinder head temp senders cost around $40 (Merc part #97465), where as e.g. Faria senders for my gauge cost around $10 (Faria part #90405).What's the difference? And I don't mean "$30..." Thanks!
  #6
Old October 18th, 2004, 06:37 AM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
It's marine certified. You're insurance won't get all bitter an' twisted and you won't end up in court if something goes wrong.Chris.........And I know they look the same on the outside.
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #7
Old October 18th, 2004, 07:16 AM
I don't understand --- my Faria instruments are marine instruments...
  #8
Old October 18th, 2004, 10:15 AM
By the way, the following document from Teleflex has some great detail about installing water temp senders, for a variety of OBs:"OUTBOARD WATER TEMPERATURE GAUGE INSTRUCTIONS," http://www.tflx.com/PDF/99625.pdf John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Temperature switch 60HP 1986. Sensor or just switch? DaMightyWackO Johnson & Evinrude Outboards 8 October 24th, 2006 06:51 PM
temperature sensor buddybuddycox Force & Chrysler Outboards 2 August 17th, 2005 12:48 PM
4.3 Temperature sensor jpg74 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 April 25th, 2004 03:54 AM
1990 Propeller For 60hp mercury Housedoctor71282 Mercury & Mariner Outboards 2 January 17th, 2004 03:54 AM
1998 Mercury Optimax temperature sensor: at what temp does it come on? milo98 Mercury & Mariner Outboards 8 November 10th, 2002 11:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
