I'm buying a boat this weekend with a 96 200 Merc which has been rebuilt. I may be taking on a project. Please let me know what you think.<br /><br />The owner last ran it this summer when it started making an intermetent knocking sound. He returned the boat to its lift and had a Mercury tech take a look at it at the dock. He says that the tech said that one of the carbs in running lean and cleaning/adjusting the carb(s) may fix the problem.<br /><br />After a battery charge, we started the motor yesterday. It started fairly easily. I heard the knock which happened randomly 3-4 times a minute at idle. I did a compresion check and it had 130psi on all 6. I pulled ignition wires one by one as it ran and only heard a drop on the two middle cyls.<br /><br />Could the knock be occuring only because there is no ignition in one or more cylinder, or, is this going to take more time and money?
