  #1
Old August 13th, 2004, 12:22 PM
BoneDigger BoneDigger is offline
Default 90 HP Mercury idling issues...
This is a 2000 model 2-stroke "classic" design. It does well at idling speed when I am trolling, but when the boat is in neutral, it will run great for a short time, sputter, then shut off. It cranks right back up, runs fine for a minute or two in neutral, sputters and dies. Cranks right back up... It will troll at 2.5 mph all day without a hitch. Any ideas?Todd
  #2
Old August 13th, 2004, 02:45 PM
steam_mill steam_mill is offline
Default Re: 90 HP Mercury idling issues...
I've got the same engine. The same thing happens to me when I first start it up if I have not either pumped the bulb at least 10 times or not have moved the idle lever (?) far enough.When warm, it will not stall. I suspect your idle may be too low. What are you idling at?Joe
  #3
Old August 13th, 2004, 10:05 PM
Wellcraft 89 Wellcraft 89 is offline
Are you having any high rpm surging at all ?chk fuel vents chk your air mixture screws,mine had the middle one ,not the same as the bottom and top from the factory ran okay first couple times out when new ,but started to stall the same as yours.adjusted runs fine now.fuel pump could be starting to act up also carbs could be dirty or gummywhat do the plugs look like? all the same or one different?Rich
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 110 (9.8 HP) dies when shifting or idling down. WardenJ Mercury & Mariner Outboards 5 May 27th, 2008 06:19 PM
Mercury motor impeller and idling Augwen Mercury & Mariner Outboards 7 January 4th, 2007 12:48 PM
1987 50 Mercury rough idling Ricky&Lisa Mercury & Mariner Outboards 2 April 15th, 2005 07:05 AM
Mercury 75.....1984? Idling rough PLEASE HELP? varouth Mercury & Mariner Outboards 1 May 20th, 2003 09:12 AM
1999 175 Mercury SportJet stalls when idling CaptRonR Mercury & Mariner Outboards 3 November 9th, 2002 05:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
