  #1
Old August 12th, 2004, 08:12 AM
Nitrox Nitrox is offline
Default Mariner 150 Magnum III Battery Charging or not ??
I have a Mariner 150 Magnum III 91 / 92 vintage. On the whole the engine has been very reliable but of late we have broken down at sea twice. Once with Divers in the water and 12 miles off, very scary !For some reason the engine just cuts out after period of running, (this just maybe a stall related to the time spent with engine on idle while divers are in water - not main concern). Problem is just lately then engine has not always restarted - issue.We have checked just about everything and replaced the wiring harness which was defective (short when can in contact with water). But lately we have noticed that the battery charging circuit / rectifier may not be working leading to a flat battery. Assumption engine runs on battery for electrical power which decays battery to point where engine fails or unable to start engine after a stall ??)Our instruments are showing 12.4 volts whether engine is running or not ????? This does not appear right to me. I would expect the voltage to be higher voltage output when engine is running and charging battery i.e. 13.5+ V.Question: How can we check the output of the rectifier ? Or check whether the rectifier is working or not ? Is their any values to check ? All ideas welcome. Thanks
  #2
Old August 12th, 2004, 03:08 PM
bhile's Avatar
bhile bhile is offline
Default Re: Mariner 150 Magnum III Battery Charging or not ??
You already checked it. But to be sure, put a volt meter or multimeter directly on your battery and check voltages running and not running. It should be higher with motor running. If you indeed had a shorted wiring harness, there is a 99% chance your rectier is shot.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old August 12th, 2004, 08:34 PM
ronmold ronmold is offline
If you have a meter put it on the AC range and check the yellow wires on the rectifier with the motor running. At high idle you should see 13 to 15 volts. If volts are low try removing one of the yellow wires from the rectifier lugs and test them. If you have lots of AC voltage but low DC when rec. is hooked up it is your rectifier.
  #4
Old August 13th, 2004, 04:13 AM
Gents, Many Thanks for your responses they are both very useful. The point ref the defective harness may indicate the cause of the problem particularly as the harness fault was found to be defective insulation on the harness running through the hull. We found when the harness came into contact with water in the bilge it cause the starting electrics to short out. Thus it is feasible that running like this make have wrecked the rectifier. The test information is very useful which I will try this weekend but it looks like a new recifier maybe required.Again thanks for your collective help !!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
45hp 1986 Mariner not charging battery perdidojoe Mercury & Mariner Outboards 2 May 27th, 2004 10:55 AM
45hp 1986 Mariner not charging battery perdidojoe Johnson & Evinrude Outboards 1 May 27th, 2004 10:17 AM
'95 Mariner Magnum 150 not charging cranking battery mknaron Mercury & Mariner Outboards 3 January 28th, 2004 03:12 AM
charging rates on 105 crysler magnum HAPPYBOAT GUY Force & Chrysler Outboards 5 July 10th, 2003 03:12 PM
Mariner battery charging voltage too high bpet298 Mercury & Mariner Outboards 0 August 6th, 2002 07:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
