  #1
Old August 10th, 2004, 05:20 PM
Drobles83 Drobles83 is offline
Default 7.5 Mercury drive shaft not aligned correctly
I have a 7.5 Mercury 1983. When I replaced the impeller, the drive shaft did not align correctly. Now my neutral is closer to the reverse on shifter and I end up starting the engine while in foward gear. And my reverse does'nt work. Can you tell me how I can align the lower unit in order for gear to be correct on shifter? Not very convenient starting in foward and unable to go reverse. Thank you for any help offered.Drobles83
  #2
Old August 10th, 2004, 05:28 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: 7.5 Mercury drive shaft not aligned correctly
You'll have to drop the lower unit again. Select neutral on the lower unit. If you don't have a spare shift shaft laying around use a small shifter closed up on the splines (not really recommended, but sometimes you can only use the tools you have). Then select neutral on the engine selector lever and bolt it all together again. Easy!Chris...............
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old August 11th, 2004, 07:59 AM
New at boat motors, probably stupid question. How do you go about selecting neutral on lower unit? Before I lower the lower unit should I have the shifter on Neutral and then lower lower unit?Thanks for info, you are really helping alot.Drobles83
  #4
Old August 11th, 2004, 09:52 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
The easiest way to shift the lower unit off the motor is with a pair of pliers - just don't use them on the splined area. In neutral, the prop will spin freely. In forward, it will "ratchet" in one direction. In reverse it will spin freely about 60-degrees in either direction and then spin the driveshaft. I the unit is in neutral and the shift handle is in neutral, you're home free...- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #5
Old August 11th, 2004, 10:21 AM
jajeeper jajeeper is offline
See the instructions at the bottom of this link: http://www.brokeboats.com/newpump.html
  #6
Old August 28th, 2004, 09:02 AM
I want to thank Chinewalker and Jajeeper for their help in aligning my shifter on lower unit. Worked like a charm last night. Thanks fellas.Drobles83
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop shaft bent?... or mis aligned? VolvoSX gregtay Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 17 August 11th, 2006 08:42 PM
Cant get shaft aligned tootoot Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 October 18th, 2005 12:45 PM
mercury 9.8 Drive shaft needed matrix29 Mercury & Mariner Outboards 2 August 23rd, 2005 05:06 PM
Mercury 25 - Cracked drive shaft housing jakeboomer Mercury & Mariner Outboards 3 February 2nd, 2005 01:15 PM
Removing drive shaft/prop shaft bm258 Johnson & Evinrude Outboards 4 June 29th, 2004 08:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
