  #1
Old August 7th, 2004, 05:09 AM
daviddustyy daviddustyy is offline
Default Mariner 50 cont beep temp plus loss of top end
Please help as I am at a loss with this now I have a mariner 50 1990-91 the boat starts fine it dose not get hot and the oil mix is fine too I have however the continues beep sound coming from the throttle control and like most of the posts it seems the easiest way to get rid of it is to turn the key back a bit without cutting the engine right off (dodgy switch)???All of the connections are clean in the throttle box and also in the engine its self the compression is ok too kicking out 125 on each cylinder I have cleaned the carbs and put in new plugs also if I disconnect the temp wire that comes out of the block it stills stays on but if I disconnect the small black box situated under the starter that also connects to the temp wire the beep stops hooray!!!But the biggest problem is the engine is holding back and I only know this because every now and again on full throttle it seems too clear for a few secs and the boat takes off J is the elec problem causing the lack of power or is it two problems?Any thing im missing here ? daviddustyy@aol.com
  #2
Old August 7th, 2004, 06:23 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Mariner 50 cont beep temp plus loss of top end
Welcome to iboats.I'd like to get this straight in my mind. Are you getting a beep beep beep, or beeeeeep? Beep beep beep is an oil warning, beeeeeeep is an overheat warning.The alarm continues if you disconnect the overheat sender and that should indicate that it isn't the problem (still could be, but let's assume it's not). The black box is the warning module. If that fails, you can get a constant beeeeeeep. There should be a couple of wires coming out of the bottom of your oil tank. Disconnect one. If it's a beep beep beep and that stops, then the float in the oil tank probably doesn't float anymore. If that's the case, you need a new oil tank.Right now I'm leaning toward a bad warning module, but try the oil tank test first.I don't think you have a feature that would limit the RPMs if you get a warning. I think your running issues are separate from the alarm.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old August 7th, 2004, 07:13 AM
its not a beep beep its a beeeeep and i can stop it by disconnecting the brown wire coming out of the little black boxas for the poor top speed is there anything on the ignition switch that could cause this because i did start to take the throttle control off the boat but it was too choppy at sea so i went back in to finish the job off on land and it seemed a little better on the way back in not sure if i had disturbed something as it was ok for longer period.
  #4
Old August 7th, 2004, 07:21 AM
also the engine is pumping water ok and not getting hot so i guess it the module but the real bummer is not being able to go flat out could this also be cause by bad tank breather or water in the fuel?
  #5
Old August 7th, 2004, 07:51 AM
ronmold ronmold is offline
When you say the problem "clears" for a few seconds is it like someone throws a switch and the motor just takes off? Also does the motor run rough and shake when you open the throttle and it doesn't go? I repaired this problem on my 175 by replacing the switchboxes. Is the wire you disconnect brown(tan)/blue? If so it is the oil warning module and if it gives a solid buzz and not beep beep as it should it is defective.
  #6
Old August 7th, 2004, 07:57 AM
the wire i disconnected is brown(tan) switchboxes???yea it is sort of rough when you open it up but idle is fine but yes that is what its like when you say its like flicking a switch because its like the engine is governed to half its rev range i cant get it to screem if you know what i mean.
  #7
Old August 7th, 2004, 08:01 AM
thanks for you help by the way!whats the switchboxs and where are they located ?
  #8
Old August 7th, 2004, 09:46 AM
Many thanks to all of you but im still stuck
  #9
Old August 7th, 2004, 03:37 PM
not sure on a 40hp but it is where the red & blue stator wires & trigger wires go. It has lots of terminals on it.
  #10
Old August 8th, 2004, 12:16 AM
excellent thanks very much my friend!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Merc 200HP motor going "beep beep beep" barber702 Mercury & Mariner Outboards 10 August 12th, 2006 08:07 AM
beep....beeep....beep...when motor is in the water tsgarbi Mercury & Mariner Outboards 2 July 2nd, 2006 08:21 PM
Mariner 150 - constant beep but oil is fine ? Gnirts Mercury & Mariner Outboards 5 August 5th, 2004 03:41 PM
Merc 60 hp outboard Beep Beep Beep pcobb Mercury & Mariner Outboards 6 July 6th, 2004 05:19 PM
How do I hook up the beep beep thingy when starting engine 96,75hpforce Mercury & Mariner Outboards 1 March 29th, 2003 02:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
