  #1
Old August 4th, 2004, 10:19 AM
Gnirts Gnirts is offline
Default Mariner 150 - hard to cold start and stalls on low revs
Hi,We've recently got a Mariner 150 engine approx 10 years old and it doesnt seem to like cold starting very well. To get the engine ticking over without stalling it requires nearly full hand throttle.In addition to this, when on very low revs for slow speed it has a habit of occasionally stalling requiring a restart, again with the hand throttle raised to get it going.Can anyone post a trouble shooting guide or some advice on what to look at to identify the problem ?Thanks
  #2
Old August 4th, 2004, 12:16 PM
Keith Buchanan Keith Buchanan is offline
Default Re: Mariner 150 - hard to cold start and stalls on low revs
First thing to do is a simple compression test. If they are close on all pots new spark plugs and high tension leads are the order of the day. Plugs and leads are 90% of the problem in my experience. Either you will have cured your problem or you will have eliminated a whole bunch and post back for further tips..Good luck Keith B... keep it simple.
  #3
Old August 4th, 2004, 01:49 PM
OK. Spark plugs will be changed tomorrow when they arrive so at least we can eliminate that. Will post back in a few days when i get back if it hasnt cured it.Thanks for the reply.
  #4
Old August 4th, 2004, 05:12 PM
KCLOST KCLOST is offline
If you have to advance the throttle that much to get it or keep it running, it sounds more like a fuel issue....Go ahead and replace the plugs, but it may be time for a carb rebuild.... May be your low speed jets clogged up...Are you priming the bulb prior to starting it cold?
  #5
Old August 4th, 2004, 06:03 PM
Yep bulb is primed and hard before starting attempts.I noticed the fuel filter looks to be 90% full of rubbish - could this be affecting the starting or isnt it a problem?
  #6
Old August 5th, 2004, 05:11 AM
Yes, the filter can restrict fuel flow....replace it and retest...
  #7
Old August 5th, 2004, 07:00 AM
dingbat's Avatar
dingbat dingbat is offline
With a motor that age it's time to change out the fuel pump diaphragm also. Low fuel pressure could be a reason why it runs OK when you open up the throttle a little ways
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
  #8
Old August 5th, 2004, 03:44 PM
We think its about 10 years old but cant find a serial number on there to attempt to ID the year.All thats written on the top of the engine block is "V150" and on the actual cylinder: 87976AS / 3400On the starter motor area, 50-7714?? 10 3 90Changed the spark plugs today and cleared the fuel filter and it seems to start better, no hand throttle needed and generally idles OK but dropped out once or twice.
  #9
Old August 6th, 2004, 08:14 PM
ronmold ronmold is offline
serial # should be on the tilt/swivel bracket, starboard side
  #10
Old August 13th, 2004, 05:23 PM
OK the serial number reads:0D056850Ive looked on http://www.marinshopen.se/ and think it might be a 1991 V150 or V150 Magnum 2. Is this correct? If its the right year i'll order a maintenance manual for it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
hard start when cold JV1964 Mercury & Mariner Outboards 19 February 1st, 2007 10:40 AM
hard start when cold brushhog Johnson & Evinrude Outboards 2 September 6th, 2006 01:06 AM
hard cold start rods Johnson & Evinrude Outboards 10 January 25th, 2006 11:55 AM
Hard cold start sunpacman Yamaha & Suzuki Outboards 13 August 22nd, 2005 10:54 AM
mid-1990's mariner 3 cylinder 60 hp hard cold start kentrx1 Mercury & Mariner Outboards 4 July 17th, 2005 05:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
